04-02-2013, 10:42 PM | #1 |
13
Rep 151
Tons of Threads on Burning Oil But None on Solutions?
As everyone has noticed there are tons of threads on burning oil but not one of them gives an answer. My car also burns oil ALOT, 1 quart of 5W30 every 600 miles.
Has anyone gone to service and gotten a fix for this problem yet? |
04-02-2013, 10:51 PM | #2 |
456
Rep 2,586
PLEASE don't put the 5W-30 oil, go to a BMW dealership and pick up the Castrol 10W-60 oil!
04-02-2013, 10:59 PM | #3 |
13
Rep 151
I hope your kidding, because the new Twin Turbo M's require 5W30 as stated in all the oil threads on this forum and in the cars handbook itself. However I'm not asking about what kind of oil to use but instead wondering if anyone with the same problem as me has found a solution.
04-02-2013, 11:17 PM | #4 | |
456
Rep 2,586
04-02-2013, 11:39 PM | #5 |
237
Rep 1,095
Drives: 09 SC E90 M3 / 13 F10 M5
I'm wondering the same thing as I have 2 bottles of extra oil always sitting in the trunk. I didn't realize these are 2 stroke engines. lol
04-03-2013, 05:26 AM | #8 |
20
Rep 102
Drives: RRS Supercharged / 991 Turbo S
04-03-2013, 08:17 AM | #9 |
Rep 139
That oil consumption is excessive, indicating something is not right with the engine. I'd take it to the dealership and have them check for leaks and do a compression test. I'd want to know what the number is.
To keep oil consumption down, the break-in is absolutely critical. You want to run the car at a number of different speeds, rpms and gears in the first 2,000 miles. You do not want to go full load/throttle or above 4,000 rpm for this time. Wherever possible, you want to avoid cold starts as much as possible, so try not to take a lot of short trips where the car sits overnight. I always plan a long drive on the backroads when I pickup a new car (500 miles or more). You absolutely want to change the oil at 2,000 miles or so. There is all sorts of crap in the oil at this point, and when you go F.T. and high rpm, you don't want a bunch of metal particles in the oil. Once you hit the 2,000 miles and changed the oil, gradually work up to F.T. and max rpm over the next few hundred miles. If you break the car in this way, you will burn the minimum amount of oil. I've put over 100,000 miles on my E60 M5 along with many track days, and it used 1 liter/5,000 miles consistently it's whole life. My Porsche was broken in the same way, and since I haven't tracked it or driven it quite as hard as I did the M5, I'm using less than 1 liter/10,000 miles. |
04-03-2013, 08:27 AM | #10 |
256
Rep 4,721
for mine, 1st 8,000km or 5,000 miles ... I do 1 qt for every 1,000km or 600 miles. Since then, I am doing 1 qt for every 1,600km or 1,000 miles.
In comparison to my old 2011 550, I did 1 qt for every 5,000km or 3,000 miles (on average). |
04-03-2013, 08:54 AM | #11 |
Knight Commander
554
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
I think it has to be something to do with driver usage pattern. I have owned an N63 and an S63TU and in both cases I have virtually no oil usage. It would be 20k miles before I need to add a quart on my car. And on the N63 it was even less usage.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
04-03-2013, 08:54 AM | #12 | |
3486
Rep 9,709
04-03-2013, 08:56 AM | #13 |
120
Rep 1,246
Drives: 2015 LBB F85 X5M
i also add 1 qt every 1500 miles...
this is not normal... in every 5 visits to a gas station, i have to tap up the oil |
04-03-2013, 09:04 AM | #14 |
13
Rep 151
I broke my car in exactly as I was supposed to but it still burns a ton of oil. I just don't wanna go to service with this and have them take apart my whole car looking for an answer (we all know they never put it back toghether as well as it was), but it seems I have no choice.
04-03-2013, 09:19 AM | #15 |
495
Rep 1,106
If your car is producing full power and you notice no ill effects from the exhaust, e.g. oil smoke, I would just wait to get more miles on the car and see if the oil usage trails off. The last thing I'd do is have a dealership tear down the engine just because its using a litre of oil every 1K miles and is running great. YMMV.
Bish |
04-03-2013, 09:33 AM | #16 | |
62
Rep 481
///M
04-03-2013, 09:38 AM | #17 |
23
Rep 180
The F10 M5 and F12/F13 M6 are known to burn more oil than previous M's. But for comparison, I have a bit over 5,000 miles on my M6, and have only had to put in 2 quarts of oil over that period. Every 600 miles does seem out of the norm from the other responses I have read. Also, it seems from these other responses that oil consumption goes down with more miles on the car. Just my 2 cents.
04-03-2013, 09:42 AM | #18 |
23
Rep 359
My M6 is just getting a little better now, it was at 1200, 2000, 4000, and 7200 was just my last fill up.
Need to get away? http://www.daringvacations.com
04-03-2013, 09:50 AM | #19 | |
13
Rep 151
Thanks For the advice ill wait a little longer. Just another question, because of my problem I check my oil every 200 miles, is it bad to wait for it to need a full quart, should I be filling up every time it's low half a quart? |
04-03-2013, 09:57 AM | #20 | |
Knight Commander
554
Rep 5,948
04-03-2013, 10:26 AM | #21 |
Live for today tomorrow never comes
1988
Rep 9,498
Yep me too, My E90 M3 and F10 550i m Sport used NO OIL at all over 10K miles each.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
