Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Help real fast!
      04-01-2013, 10:40 PM   #1
NJ | 330
25
Drives: Monaco Blue 330xi
Help real fast!
I was that that if you pull fuse number 20 that it would make the xi into rwd. I'm looking in the fuse box right now and there 5 different fuses with "20" on it. Help please
_______________________________________________
| 330xi Monaco Blue | CF Spoiler | AA Exhaust |
| OSS Angel Eyes | CF Interior | "Performance" Intake |
      04-01-2013, 10:47 PM   #2
NJ | 330
25
      04-01-2013, 11:47 PM   #3
07lilredwagon
07lilredwagon's Avatar
40
Drives: 07 328 wagon
I dont think you want to do that...these cars are set up to run all 4 wheels at the same time. They are also supposed to be running the same size tires....
The transfer case will probably get angry and I mean in a physical failure sort of way, if you try to run one end of the car without the other one knowing about it. If the car senses that the drive system is out of whack, it could limp mode on you or not run at all....
I know what you are saying...and why you are asking...but I would say no....
JP
      04-02-2013, 12:38 AM   #4
NJ | 330
25
You lost me when you thought I was changing my tires..
      04-02-2013, 08:20 AM   #5
07lilredwagon
40
I dont think that...what Im saying is that you cannot make our 4wd cars 2wd because the rear wheels are rigidly mounted to the drive axles which are rigidly mounted to the rear differential, which is rigidly mounted to the drive shaft which is rigidly mounted to the tranny, which is rigidly mounted to the transfer case which is rigidly mounted to the front differential...ect
the leg bone is connected to the hip bone..know what I mean?
I was saying that if you artificially try to do this, it wont work because you cannot just simply "unplug" the system. its a mechanical thing.
JP
      04-02-2013, 11:08 AM   #6
Cuba
Cuba
Cuba's Avatar
81
Drives: 07 328xi
Don't do it. Not worth the potential damages
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
      04-02-2013, 02:21 PM   #7
kfriceman
52
Drives: 2009 335 xDrive E90
If your information is correct that means pull fuse number 20, what your picture and desciption is indicating is 5 ea. 20 amp fuses. You seem to know little to none about what your trying to do here.....this could mean big trouble for you later.
If you want your Xi to behave like a RWD car, just turn all of the traction control system off and go nuts.......safely.
-Kevin
      04-02-2013, 02:34 PM   #8
shadow191
181
Drives: 2017 Volvo XC90 R-Design
http://www.e90post.com/forums/showthread.php?t=466454
Looks like it is possible, but there are downsides. Why are you trying to do this? The only reason I could think of is you're planning to dyno the car and they only have a 2 wheel dyno. Other than that, there's no point unless you're planning to "drift"...
      04-02-2013, 02:58 PM   #9
JaysBlueE92
Mr. Monaco
JaysBlueE92's Avatar
155
Drives: Slow..
2007 E92  [5.00]
JP
False - sports package comes with staggered wheels and different tire sizes from the factory.
      04-02-2013, 03:00 PM   #10
Slow_335i
Daily Driven!
Slow_335i's Avatar
186
Drives: BMW 335i
2008 BMW 335I  [7.02]
YOLO Just do it... (trolling)
      04-02-2013, 04:09 PM   #11
zmiller08
Drives: 2008 e90 335xi
Really...
I hope this is a joke if pull fuse 20 doesnt mean 20 amp
straight pipe mhd led interior dci syle 95s m3 high spoiler
      04-13-2013, 06:42 PM   #12
Envuks
Envuks's Avatar
26
Drives: '08 e92 335xi
The numbers on the fuses are their spec. You need the fuse map (piece of paper on the side) that should be in your fuse box to determine which is number 20
Jet black e92 6mt 335xi:
18" BBS RGRs, KW v1, ESS Stage 2 flash, VRSF 7" FMIC, VRSF downpipes, JG Mods m-tech front, mtec V3 AEs, BMS OCC, hardwired valentine 1, p3cars gauge, amber delete, sport seats, factory oil cooler.
      04-14-2013, 01:03 PM   #13
everlast
Malt'm'n'Salt'm
14
Drives: 2008 328xiT
This really made me lol.
edit: I'm still giggling.
