spacers on car making possible wheel vibrate
03-29-2013, 05:03 PM | #1 |
64
Rep 303
would 10mm in the fron and 15mm in the rear knock off balance and make the wheel and car shake? its rough around 60mph and annoying at 40 and 80mph
any help i didnt have so much shake before the spacers but i honestly do not know and some wheel balance places wont touch my car because of the spacers the spacers are bms btw |
03-29-2013, 05:23 PM | #2 | |
684
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
04-17-2013, 06:57 AM | #6 |
17
Rep 575
When installing spacers be sure to:
A) Ensure the hub size is the same, if not invest in a set of hub rings to MAKE them fit B) Clean the spacer and the hub, any bits of rust of dirt can't be in them. Any of this can cause the hub to not be perfectly aligned and cause vibrations C)Be sure to torque down your wheels in a star pattern, if you don't know what that is google it. I always take ~3 steps in tightening mine down, prgressivelt tighter each time. If you do these 3 things you should be able to get rid of any steerig wheel wobble or vibrations from the rear caused by spacers of any size. |
04-18-2013, 06:53 AM | #8 |
22
Rep 221
I had the same issue...come to find out that there were these thin plastic "spacers that go between the hub and the spacers themselves. When I put on my winter wheels the car vibrated when I hit 40-60mph. If your spacers came with those plastic spacers...put them on and it should stop the vibrations.
2008 e92 328Xi - Daily Driver
M-Tech Lip/ M-side Skirts/ Painted Grille/ 18" LM Reps/ BMS Powerbox/ Koni Sport/ B&G S2 Springs 2008 997.1 TT Porsche; 2008 Nissan Altima Coupe - Show Car; 1995 300ZX SMZ #36 |
