Guys,need your advice,please.
03-28-2013, 04:30 AM | #2 |
Rep 514
If the front and rear wheels are different widths, putting square tires on them will just recreate the original problem, and you'll wreck your transfer case in a month.
You need a setup that keeps the rolling diameters between the front and rears basically the same (within a 1% difference). For those wheel sizes, 225/35 fronts, and 255/30 rears would work. You could probably run 235/35, 265/30 just fine as well if you wanted a meatier-looking tire. Last edited by Kalidian; 03-28-2013 at 04:39 AM.. |
03-28-2013, 05:39 AM | #3 |
15
Rep 238
damn......thats so complicated.....are you sure about staggering?i thought that i can just put same tires on em and it will be fine(((
Only God Can Judge Me
03-28-2013, 06:08 AM | #4 |
15
Rep 238
Im also looking to put there oem 19s from e46 m3.if someone had an experience with doing this offset on XI let me know what tires has to be installed and if any spacers needed.guys,thnx for your help and i owe a beer to each one who will help me with useful advice lol
Btw i have 328xi(i believe with no sport package,but i have sport steering wheel,strange) and stock recommended sizes 225/45/17 what is really looks like a crap...
03-28-2013, 03:44 PM | #5 | |
Rep 514
If you want to run a square tire setup then you can't have staggered wheels; a wider wheel in the rear means more surface area that the tire must stretch to cover, which will result in a difference in diameter even if the tire sizes are "the same". It won't be much, but it'll be enough I think to stress out your awd system. It's not that complicated. If you want to run a staggered setup, this is the way it is. The sizes I suggested above is the cookie-cutter setup that most xi guys run with no issues. If you don't want to worry or think about it, then don't run staggered. Just get a square wheel setup, with which you can just throw on square tires and run no problem. If you want looks (stance?) with a square setup you can just get wider tires and throw spacers in the rear. Last edited by Kalidian; 03-28-2013 at 04:13 PM.. |
03-28-2013, 06:13 PM | #6 |
15
Rep 238
Thanks a lot for your advice bud,btw does anyone knows where can i put info about set and it will calculate perfect tire sizes for awd?thats was kinda web site,i just lost the link.
03-28-2013, 06:20 PM | #7 | |
Rep 459
EDIT: Im currently running 19x8.5 19x10. Its nice, but impractical for us AWD guys. My next setup will prob be 19x9.5 all around. Lots more benefit for AWD to go squared.
03-28-2013, 08:36 PM | #9 |
Rep 514
Squared setup means less understeer with the narrower rear stance. Having a square setup also means you're able to rotate the wheels as needed for even tire tread wear. In addition, having the narrower rear wheels means you probably shave off a few pounds (unless you go super wide on all corners), resulting in your ride being marginally quicker off the line and slightly easier on the gas.
Staggered setups for our xi cars is purely for stance/looks. It offers no benefit for performance whatsoever. Last edited by Kalidian; 03-28-2013 at 08:43 PM.. |
04-01-2013, 05:38 PM | #10 |
15
Rep 238
Hey Guys,just got my wheels today,and sizes are
275/30/r19 19x10 245/35/r19 19x8 have no idea about offsets .Maybe can you tell me if this set will work on my XI? Really appreciate your time and help.
