Zaino Z-2 Pro question
11-25-2005, 09:34 PM | #1 |
16
Rep 454
Does anyone know whether you always have to use the ZFX Flash Cure Accelerator with every application of Z2 or only the initial one?
If I'm reading the web site correctly, it sounds like you only need it for the initial application. Thanks to all! |
11-25-2005, 11:41 PM | #2 |
Rep 31
I used it w/zfx for the first two applications.
Did the third alone and let it sit a few hours. Excellent results. According to my conversation with Sal Zaino today, no, you do not need to use the zfx every time. |
11-26-2005, 08:22 AM | #3 |
364
Rep 5,842
Drives: 2006 325xi
zfx helps the z-2 dry quicker and also enhances the shine just a bit. its not necessary but i do recomend it if you want to do more then 1 coat of zaino a day
12-01-2005, 05:33 AM | #4 |
442
Rep 4,838
You only need to add ZFX once (4-5 drops) per one ounce of Z2 or Z5.
One of those 2 ounce bottles should be enough to do the ENTIRE car FIVE times. (It states on the website that 8 ounces of polish can do a Corvette 20 times, if I recall correctly.) Just make sure you shake the mixture again before you apply another coat. Of course, when you're mixing another batch, you'll need to add ZFX again. Also, remember to clean out the bottle (says how to on the website) before 12 hours, so you can reuse it. |
