Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Am I Safe with Squared 18x9.0
      03-25-2013, 07:40 PM   #1
asianstutter
Drives: 2006 BMW 330xi
Hey guys,
I just ordered a set of wheels and tires from a local shop. Can you guys tell me if my setup is safe for AWD, fender rub, front too wide?
My setup is squared not staggered ( it allows me to rotate if i need to). 225/40/18 18x9.0 offset 30.
      03-25-2013, 08:28 PM   #2
mr_sk
Drives: 335i xDrive
Curious as well - I'd like to run a square setup so I can rotate as needed and get a little more "life" outta the tires.
      03-26-2013, 10:29 AM   #3
asianstutter
Anyone?
      03-26-2013, 02:24 PM   #4
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
You are fine, no problems. Even if you are lowered you will not rub.In fact i would add 12-15mm spacer to rear.
I have pre-lci with 18x9.5 et22 rear with 235/40 lowered, no fender mods and no rubbing.
18x9 et16 will extend to same point as the 18x9.5 et22.
Also i will add 10mm spacer to my setup at spring so 9.5 et12, but it will need fender roll.
Here is pre lci with 18x9 et26 front and et8 rear, but this will probably require fender roll to rear.
http://www.e90post.com/forums/showthread.php?t=461073
      03-26-2013, 02:54 PM   #5
D_o_S
LCI'd
257
Drives: 335i LCI
Wow, watch out here... AFAIK, a 9.0 rim is too wide for the front, it will hit the strut, but YMMV...
      03-26-2013, 03:03 PM   #6
MonacoBlueE90
Finland
163
Can't really tell if you are sarcastic, but 9 inch isn't too wide to front and 18x9 et30 is about 13-14mm from hitting the stock shocks inside. I have 9.5 et35 front and that is about 2mm from stock shocks and i know some people here have 10 inch wide wheel at front.
      03-26-2013, 03:30 PM   #7
Envuks
Envuks's Avatar
26
Drives: '08 e92 335xi
You're running a 235 rear tire on a 9.5 inch wide wheel?... What? Why?
Jet black e92 6mt 335xi:
18" BBS RGRs, KW v1, ESS Stage 2 flash, VRSF 7" FMIC, VRSF downpipes, JG Mods m-tech front, mtec V3 AEs, BMS OCC, hardwired valentine 1, p3cars gauge, amber delete, sport seats, factory oil cooler.
      03-26-2013, 05:08 PM   #8
rattmobbins
rattmobbins's Avatar
13
Drives: '15 Escalade, '07 530 xiT
      03-26-2013, 06:32 PM   #9
asianstutter
This is what concerns me that the front might be too wide at 9.0. So i should just get the 8.0 all around and put spacers if needed?
      03-26-2013, 07:27 PM   #10
zipstic
484
Drives: 2008 e92 335xi
2008 335xi Coupe  [10.00]
I run an 8.5 with a 35 offset in the front with a 225 tire. If you have a 9.0 with a 30 offset with a 225 tire then you would 0.25mm further away from the strut than me so you're good on that side of the wheel.
      03-26-2013, 08:45 PM   #11
BmerMeUp
BmerMeUp's Avatar
32
Drives: Cinderella: 2008 E91 328xi
When they said 9.0 is too wide, I thought they meant too wide for a 225 tire, which is true.
Tire range for a 9.0 wide wheel is 235 -> 265.
You are going to have a substantial stretch if you can find someone to do it for you.
http://tyrestretch.com/9_225_40_R18/
      03-26-2013, 09:32 PM   #12
Envuks
Envuks's Avatar
26
Originally Posted by rattmobbins View Post
Lol. Such a fail.
      03-27-2013, 02:49 AM   #13
Yvette
761
Drives: M
should be ok, i am running 9.5 squared et22
rubbing w/ 255 in the rear, so did fender roll
      03-27-2013, 06:04 AM   #14
playground
Hong Kong
32
Drives: M3
Can't even turn. smh.
Become like water my friend.
      03-27-2013, 12:12 PM   #15
MonacoBlueE90
Finland
163
Why not? Handling is more neutral, cheaper tyres and i have 320 diesel so no need for wide rear tyre to get more grip. But i guess main reason was that i wanted to fit 9.5 et22 without rubbing and fender roll. Also wanted the tyre to look the same as front stretch wise.
Picture of stanced car
My car is far from those stanced cars. Im not that low and i haven't add any negative camber and i don't have enough poke etc.
I like how you totally ignored my post above.You have no problems with 9 inch wide wheel at front.Here is my 9.5 et35 front which is 2mm from shocks inside.
View post on imgur.com
Your 18x9 et30 would retract 1mm from that and 11mm more room inside.
You can go 8 inch wide if you want, but if you want the wheels to be flush with fenders you are going to need big spacers at least for rear, if they don't offer lower offsets.Just to give you idea this is my winter setup 17x8 et20 front and 17x8 et10 rear with 225/45/17 No rubbing.
Not true 225/40/18 is approved for 7.5-9 widths and every tire shop should do it, because it is approved
http://www.alloywheels.com/225-40-18-Tyres
I don't think the stretch will be that bad, its going to be about the same as my 235 on 9.5, of course the amount of stretch depends tyre brand.Example Michelin pss are wider than falken even if the size is same.
Here is one with 18x9 with 225/40 not BMW tho.
http://www.golfmkv.com/forums/showpo...10&postcount=9
to me thats not stretched, this is.
http://img260.imageshack.us/img260/6...fitmentbi5.jpg
But these are personal opinions.
      03-28-2013, 04:00 PM   #16
sleeper6
Drives: 2008 335xi E92
I am 18x9 ET 41 square with 255/35 + 12mm spacersx4 no prob. Very little cost diff on tires (all season) 225vs 255. Looks great no rub. Now I just need to decrease my elevation
      03-28-2013, 08:26 PM   #17
projectzer0
Drives: 2015 f30 335i xdrive
I've been wondering the same thing. So I am assuming 19x9 +35 235/35/19 would be fine as well?
      03-28-2013, 08:48 PM   #18
BmerMeUp
BmerMeUp's Avatar
32
I don't think the stretch will be that bad, its going to be about the same as my 235 on 9.5, of course the amount of stretch depends tyre brand. ...
Fair enough, I stand mostly corrected!
I am suspicious of the 7.5-9.0 reference, but the source you quoted seems convincing, so I can neither disagree nor explain why one site would say "Ok" and one would would say "Not".
And yes, for this part, I agree I have heard from many that brand also plays a large part in how much perceived stretch you get.
Your examples and references are excellent - thank you for clarifying!
      03-29-2013, 02:04 AM   #19
MonacoBlueE90
Finland
163
No problem. Here is another chart. It says that 225/40/18 is for 8inch wide, but 7.5 to 9 are options too.
http://translate.google.fi/translate...neleveydet.htm
Falken tyres have the same thing.(click the view sizes & specs button on that link.)
http://falkentire.com/tires/car-tires/azenis-fk-453
Yes it will fit. Here is 19x9 et 35+ 5mm spacer
http://www.7machine.com/bmw/104052.html
