      03-21-2013, 06:45 PM   #1
HP Autosport
Supreme Allied Commander
3839
Drives: F80 M3
Smile Performance Friction V3 Direct Drive Rotors 2-piece Rotors
The Performance Friction 357.062.63 & 357.062.64 V3 Disc Rotor is a direct 2-piece rotor replacement for the BMW E9x M3 front brakes. They are designed to be used with the factory caliper, with no other parts or modifications necessary. Kit includes everything needed (rotor, hat and hardware) for a single rotor replacement. Priced per rotor.
The V3 design features an all new retention ring that holds the hat and disc together without the need for traditional nuts & bolts. The simplified design also helps save weight and makes rotor replacement a breeze. The 2-turn retaining ring is held in a groove in the hat that overlaps the rotor flanges, effectively locking the rotor to the hat.
2-piece rotors offer better cooling over a one-piece design. Performance Friction's full floating Direct Drive attachment system allows the brake disc to naturally expand/contract both radially and axially without being constrained by the hub. This helps eliminate rotor warping, vibrations and pulsations. Due to the high quality of Performance Friction's design and manufacturing, the Direct Drive rotors are completely silent and rattle-free - a trait not typically found in many competitor's 2-piece designs. The hat assembly is completely reusable - no need to buy the entire rotor again! And, because the rotor is designed for use with the factory caliper, you can still use your favorite Performance Friction brake pads!
Note: Performance Friction Brake Pads are recommended for this set up. All other pads must be checked for proper rotor clearance at installation and periodically as they wear. Some brands of brake pads will fit at time of installation, but may contact the rotor-hat during use which can lead to brake failure.
Technical Information
• V3 style mounting hardware
• High Carbon Alloy with copper and molybdenum for high temperature strength and durability.
• Vanes turned OD and ID for balance to reduce thermal warping and vibration.
• Runout less than .001 inches, reducing Pulsation and Vibration.
• Thickness variation less than .0003 inches reduces Pulsation and Vibration.
• 47 or more vanes for superior thermal capacity.
• Aircraft quality heat treated for micro structure alignment and durability.
• Surface finish less than .7 microns.
• 100% measured and inspected to meet tolerance specifications.
***Front fitment only***
***Price is for a pair of rotors***
NLA
Order here:http://www.hpashop.com/Performance-F...C-DD-1M-M3.htm
When working around brake rotors and pads, it's a great idea to have this excellent brake assembly lube(brake quiet) handy:
https://www.amazon.com/gp/product/B0...TfsgfzYiszaYK0
      03-28-2013, 12:36 PM   #2
Mahlzeit
37
Drives: 1M
Wow - great weight savings.
What's the benefit of not drilling holes all the way through the rotor?
      04-07-2013, 11:23 PM   #3
HP Autosport
3839
Drives: F80 M3
Yes, they are much lighter!
No stress cracks!
      10-02-2013, 12:09 AM   #4
HP Autosport
3839
Drives: F80 M3
Upgrade your OE rotors to these!
      01-15-2014, 10:19 AM   #5
ayao
Thread killer
642
Drives: 1M
Do you happen to know when V3s will be available?
      01-15-2014, 01:45 PM   #6
HP Autosport
3839
Drives: F80 M3
I'll check into it. Please send me an email to regarding this so I can reply to you.
harold@hpautosport.com
      01-16-2014, 06:39 PM   #7
HP Autosport
3839
Drives: F80 M3
V3 will be implemented this year for the BMW line according to PFC.
      01-16-2014, 08:08 PM   #8
HP Autosport
3839
Drives: F80 M3
Originally Posted by Ian///M View Post
Can the V3 be used with stock calipers?
Yes, it's just an updated version of the current DD rotors. There is no time frame when this will happen, PFC only said in 2014.
      01-16-2014, 10:03 PM   #9
ayao
Thread killer
642
Drives: 1M
Thanks for the followup!
      05-08-2014, 07:31 AM   #10
Splinterz88
Splinterz88's Avatar
52
Drives: BMW 1M
2011 BMW 1M  [8.86]
Any updates on DD V3 production for BMW?
      05-08-2014, 11:37 AM   #11
HP Autosport
3839
Drives: F80 M3
Please refer to post#10.
      10-28-2014, 02:48 PM   #12
Piets94
Piets94's Avatar
677
Drives: 94 M3, AW 1M, M2 CS
I do want these, but holding out for the v3 version. They look great
      10-28-2014, 03:11 PM   #13
HP Autosport
3839
Drives: F80 M3
We should see those by 2015
      03-27-2015, 07:47 AM   #14
sergeremi
41
Drives: 1 Series M Coupe
Hi, are the v3s available now?
      03-27-2015, 04:34 PM   #15
HP Autosport
3839
Drives: F80 M3
No, not yet.
      05-25-2015, 02:23 AM   #16
HP Autosport
3839
Drives: F80 M3
bump
      07-09-2015, 11:30 PM   #17
HP Autosport
3839
Drives: F80 M3
bump
      08-20-2015, 07:27 PM   #18
HP Autosport
3839
Drives: F80 M3
bump
      09-24-2015, 12:35 AM   #19
HP Autosport
3839
Drives: F80 M3
bump
      10-14-2015, 08:46 PM   #20
HP Autosport
3839
Drives: F80 M3
bump
      10-20-2015, 01:00 PM   #21
sergeremi
41
still no word on the v3s?
      10-20-2015, 01:01 PM   #22
HP Autosport
3839
Drives: F80 M3
No, not yet.
1addicts
