Eccentric shalt sensor & experts please chime in!
03-16-2013, 05:33 PM | #1 |
13
Rep 623
Brought her in for battery connector recalls & dealer did a quick inspections & informed me that I have an engine leaks due to a seal broke & oil get into eccentric sensor, appro $1300 for the job.
She runs fine& no codes found. Should I be worry or just wait until it shows code. She is at 80k miles. Thanks guys. |
03-16-2013, 06:54 PM | #2 |
BMWCCA 149159
38
Rep 847
I am fairly familar with the 335 engine and I guess I don't know what an essentic sensor is. I would ask them where it is located and what it does. This sounds very strange to me.
Before I would authorize any work I would get the diagnosis then research to see if it is critical, if they are the best place to do the work as well... |
03-16-2013, 11:27 PM | #4 |
60
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
I had no codes when my eccentric shaft sensor crapped out. Made the car impossible to start.. took a LOT of attempts to start the car. Dealer told me it was hard to get it started when I dropped it off, too!
This was over a period of about a week.. just got progressively harder to start until I got frustrated and brought it in. Approx $1500 out of warranty. |
03-17-2013, 04:29 PM | #5 |
13
Rep 623
Eccentric shalf sensor itself cost $425, they needed to remove valve cover gasket due to it locates under that & near by a timming chain.
Again, she runs just fine & no problem Of starting & driving her either & very weird? Anyhow, I will monitor it to see what' up before having a surgery on her! Thanks for your inputs guys & appreciated it a lot. |
03-17-2013, 04:43 PM | #6 |
41
Rep 284
This is where it is located
http://www.e90post.com/forums/showthread.php?t=697252 |
03-17-2013, 07:52 PM | #7 | |
75
Rep 1,035
The sensor will sometimes leak oil through it, if it gets real bad it will push the oil through the harness. It can become a problem over time depending how bad the leak is. Usually you will have some driveabilty issues and/or CEL. It may be fine now, but overtime it will get worse. They are not BSing you. |
03-17-2013, 08:41 PM | #8 |
BMWCCA 149159
38
Rep 847
Ah I see where it sits now right in the upper tensioner path. What a PITA to remove all that crap to replace a simple sensor. Can I assume the function is to verify the VANOS is in the correct position?
I learned something I didn't even know the 328 had this... |
03-18-2013, 05:17 PM | #9 | |
75
Rep 1,035
It monitors the position of the eccentric shaft, not the VANOS |
