Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > HELP ASAP!! wheel alignment after KW V1 install
      03-16-2013, 11:25 AM   #1
SyL3nTFoRcE
64
Drives: 2008 335xi
Im trying to do a wheel alignment at my cousins shop but since im lowered alot on KW V1 we cant follow the stock specs on the alignment software
Anyone have any input please?
      03-17-2013, 12:43 AM   #2
Cuba
Cuba
Cuba's Avatar
81
Drives: 07 328xi
I would just try to get as close to stock as possible.
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
      03-17-2013, 07:11 AM   #3
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
FWIW here is what I did. . Front you can only adjust toe, go for zero or very slight toe-in. Rear try to match the camber in front (whatever it is) but no more than -1 to -1.5 deg each side. Toe in about .2 degrees total.
This is what I set my car at and it feels pretty good. Was only able to get -1 to -1.2 deg neg camber in front but I have Koni/Eibach and not as low as you. You can supposedly pull the locating pin in the strut hat and get another -0.5 deg or so in front, have not done that yet.
So summary: ideally you want zero total toe in front, whatever camber. Match camber in rear up to a degree or so and some more toe in for stability.
