Mo Turbo Mo Problems
03-08-2013, 12:14 PM | #1 |
597
Rep 534
Over all in the long run I’m on the no turbo and bigger displacement side. If you are a 2 year owner then sell why should you give a f**k
Turbo or multiple of them vs. straight up displacement and overall reliability is what this post is all about. Discuss and enlighten me…..
03-08-2013, 12:21 PM | #2 | |
52
Rep 393
2011 335i e92
JB4 Stage 2, VRSF chargepipe, VRSF downpipe, Hankook Ventus V12 evo2s |
03-08-2013, 12:21 PM | #3 |
Rep 84
For me its the fun factor. I don't know what it is but a FI vehicle is just more fun to drive. I actually prefer a supercharger over a laggy turbo. Plus you can build more power on the cheap if the internals are already there - upping boost and a tune can often net 60+ HP.
That said, most people that drive a vehicle because its fun and easy to make more power aren't overly concerned about reliability. I don't expect my 335i to last 200,000 miles without some major repairs but I didn't buy it because its cheap/reliable/economical either. |
03-08-2013, 12:25 PM | #4 |
Rep 46
Right now I have an E46 but am trying to decide between a 335i or a 328i/330i. I like having a turbo on the interstate, it just seems like you get more usable highway passing power
03-08-2013, 12:28 PM | #7 |
597
Rep 534
This is not the point of this thread re-read.....
03-08-2013, 12:29 PM | #8 |
One cam is enough
132
Rep 6,801
Not going back to turbos unless I go diesel or until CAFE forces everything to be turbocharged. Haven't had the best luck with reliability on my turbo cars, and I definitely feel more connected via the throttle in NA versus turbo, even though the 335 did a pretty good job of managing lag.
Also heat soak is a bitch. |
03-08-2013, 12:31 PM | #9 |
10
Rep 191
if you're not going to allow power between NA and turbo motors into the discussion then there is no discussion, NA wins over turbo motors in reliability hands down.
03-08-2013, 12:32 PM | #10 |
597
Rep 534
ok fair!
03-08-2013, 12:34 PM | #11 |
132
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
The turbo itself doesnt make the car any more or less reliable, assuming the turbo is a quality piece. Look at turbo-diesel trucks for example. The engines are running high boost for 250k+ miles, no problem. The reason they last so well has to do with the diesel side of things, and the quality of the engine internals/turbo. they last forever.
What im trying to get at is that assuming you have high quality turbos (which IMO the N54 does not, factory), then i would much rather have FI over NA. Much easier to eek out more power, fun to have the boost feel, and much more daily drivable.
03-08-2013, 02:12 PM | #12 |
One cam is enough
132
Rep 6,801
I know I'm probably splitting hairs here, but the turbos do because you're adding a (as opposed to replacing an existing) complex piece of hardware in the system. There's also the fact that they contribute massive amounts of heat, which is the enemy of everything under your hood.
03-08-2013, 03:13 PM | #13 |
818
Rep 2,869
Turbo=power power and better gas mileage... some turbo 300-400 HP cars can get like 30 mpg... a NA engine with the same output probably wouldnt get nearly that much.
Turbo's are hard on oil though, you need to stay on top of oil changes even more so than regular engines. NA engines will always be nice and smooth, no lag, and fun to drive... BUT Turbo cars are the "Way of the future" ... solely for gas mileage purposes. ....remember like 5-10 years ago and all the "fast and furious" stuff came out? and everyone (including me - i was 16 years old and had a mitsubishi eclipse) wanted some Japan FWD, turbo 4-banger? ...well who knew they were going to almost start a real trend. car manufacturer's saw how much power you could crank out of a little engine, and boom... BMW is now a turbo 4-banger instead of the classic/famous inline 6. Its just the way things will go. You want a NA beast, you better go out and get a V8 M3 because in the coming years you will not be able to get something like that from BMW, or any car manufacturer.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
03-08-2013, 03:16 PM | #14 | |
818
Rep 2,869
kind of like saying AWD can have more issues; because they have more parts. very fair point, turbo cars can be just as reliable but you must maintain them very good. Turbo's do run HOT, so oil and coolant/cooling system are huge.
03-08-2013, 03:38 PM | #15 | |
132
Rep 2,489
03-08-2013, 04:06 PM | #16 |
24
Rep 857
Drives: 2008 Montego Blue 335i
Cam in a LS motor can add as much power as basic tunes for turbo motors. A cammed Z06 can get 25mpg highway in 6th and put down 500+whp... Not all NA are like this, but it can be done in a performance car.
03-08-2013, 04:06 PM | #17 | ||
One cam is enough
132
Rep 6,801
I can definitely see why people would prefer turbos though. I just don't. |
03-08-2013, 04:34 PM | #18 |
157
Rep 637
Drives: e90 n54
I think both engines have their pros and cons. Turbos ARE the future and because of this they are getting more reliable. They bring better gas mileage, easier tuning, and the sound of the spool. NA engines are usually rock solid reliable engines, but still have their problems. Often, they have a better exhaust note than turbo engines. The power is immediate and ready to go as soon as you turn it on. Sad to say it, but a NA m3 will soon be legend in the bmw world.
LOST BUT NOT FORGOTTEN 2009 E90 335i AW... Black grills/jb4/lux angel eyes/clear side reflectors/and a few more small mods
2011 e92 335iSSSS Black |
