Broke my wheel lock key!
03-05-2013, 04:08 PM | #1 |
129
Rep 820
Hey everyone, so last week i replaced all my pads and when i put back on my wheel i broke my wheel lock., luckly i was able to remove the rest of the wheel lock key from the bolt but now i need a new key.
I bought it from this forum member, so i don't have any receipt or S/N So Please help my find the pattern before i have a flat tire ;P thanks |
03-05-2013, 04:28 PM | #2 | |
20
Rep 1,361
03-05-2013, 05:20 PM | #4 |
58
Rep 665
It's impossible to tell just by looking at it. A dealership should have a master set and may be willing to try different keys until they find the one that fits. They may charge you for that service though since it could take some time.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
03-06-2013, 11:23 AM | #6 |
170
Rep 1,843
that looks like a McGard or similar lock not a BMW lock
get a set of "Bolt-Outs" and remove all and buy a new set (if you feel the need to have new locks) |
03-06-2013, 01:24 PM | #7 |
Rep 164
I had a similar problem with my son's Jetta. I took it to a competent welder and he welded lugnuts to the locks. Put a lug wrench on the nut and spun them all out. I replaced the locks with regular VW lugnuts I had around otherwise I would be buying new locks. It didnt hurt the wheels at all. The locks on his Jetta sat way down in the lug hole. Im suprised the guy was able to get a weld on them.
03-06-2013, 01:25 PM | #8 |
23
Rep 105
I had my local Discount Tire remove some wheel locks on a used car I bought that came with no key. The thing they used chewed up the locks pretty good but that was irrelevant. Call a couple tire shops in your area; i bet this is a situation they deal with regularly.
03-06-2013, 02:10 PM | #9 |
ALL RIGHTY THEN
222
Rep 2,957
^this. i had to do the same when i lost mine. i actually went to the parts department and provided model year, VIN# and they gave me the schpeel. then the parts manager had me pull into the service area and he went through each key in his set. they didn't have the one i needed in stock so he sold me his.
BMW CCA Member 483866
03-07-2013, 01:21 PM | #10 |
597
Rep 534
I have a solution. May not work on that type of lug nut but works very well on others. Get a 20mm socket and a hammer. If the nut is standard in circumference then it should fit snug around the lug nut. Take the hammer and hammer it on further. Then take your socket wrench attach and leverage the nut off.
Good luck op and no i do not steal peoples wheels...... Oh if 20mm does not work try other socket sizes till you find on that fits snug, then hammer on and follow the rest of my directions. be prepared to ruin some tools so use cheap stuff.
03-07-2013, 05:35 PM | #12 |
Just a normal member.
171
Rep 3,404
I hate those gay shapes. always break. That's why you should get OEM. cheap and only 10 bucks maybe less. simple design. hard to break in if you don't got the key.
03-15-2013, 06:52 PM | #13 |
129
Rep 820
Update: im very very lucky!!!
Today i went to port chester bmw dealer. I showwed him my broken wheel lock key. (In the mid time i was able to remove safely one bolt) and i showed it to the guy, he was like "oh i dont think im going to be able to find that one, bmw has 60 differets locks, but let me check i have 6 in store" and the first one he tries, guess what!!!????!!!!!! Thats the one!!!! So the lock number is #60 |
03-15-2013, 07:26 PM | #14 | |
Rep 119
02-10-2015, 05:53 PM | #15 |
158
Rep 1,314
I have the same type of wheel lock in my car. I just purchased my CPO 535 from the dealer. I just had the same issue and I am pissed off. Is the only solution to go to a bmw dealer to get this checked out and have them try all their wheel lock?
