Koni Yellow adjustment without removing strut brace bolt
03-04-2013, 12:29 PM | #1 |
36
Rep 311
Just thought i'd share:
I always hate having to remove the strut bolt just so I can adjust my struts. I have tried needle nose pliers, right angle pliers and very small wrenches (like 4mm) without much luck. I once even over torque that bolt and snapped the head off, thank god I didn’t mar the threads and was able to extract the remaining bolt. I drilled two adjacent holes and used a tamperproof screw driver bit (off topic). I even tried to cut down the original plastic adjuster knobs and make them fit only to find out there isn't enough clearance with the strut brace. My solution was to take a narrow piece of steel, and cut a 1/8" slot (die grinder and cut of wheel) so it can fit on the adjustment tab. I cut one slot parallel and one perpendicular to the tool. The perpindicular side can be used when space get tight around the strut bolt. It works well and makes adjustments in half the time. Edit: found out the perpindicular side cut isn't needed, the parallel slot works fine by itself. Last edited by critical05; 04-10-2013 at 04:57 PM.. |
03-06-2013, 07:08 PM | #2 |
684
Rep 1,434
Thats cool. I have never adjusted mine because I had the same problem. Thanks for the info.
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
04-10-2013, 06:36 PM | #4 |
294
Rep 1,834
Drives: 08 E90 335xi TiAg
Hmmm. Had these installed a few weeks ago and I don't have the boot on top of mine. Its bare. Is that a bad thing? Did my mechanic forget to put them on????
04-11-2013, 06:24 AM | #5 |
36
Rep 311
The boot doesn't fit because of the tab, i drilled a hole in them so they fit.
Without the boot, dirt can make it down to the ball bearing and cause premature wear. |
03-17-2015, 11:19 AM | #7 |
36
Rep 311
It could be the difference in Coupe and Sedan. Where the strut brace bolts onto the strut tower, there isn't enough space to get the little tool i made under the bar.
