Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Just got staggered wheels, need help to go lower now please
      03-03-2013, 08:19 AM   #1
SyL3nTFoRcE
64
Drives: 2008 335xi
Whats up everyone,
What would you all recommend suspension wise for a xi with 225/40/18F 35+ 255/35/18R 42+ i do have a staggered setup but i am running the safe measurements hopefully?
I was thinking about Megan racing coilovers since KWV1 are about 1200$?
Also if i decide to lower the car and possibly add 5-10mm spacers what would i need to add or change and is it safe?
I am not really a suspension person so help on this would be greatly appreciated before i buy it next week.
Thanks in advance
Pics of my car and how she sits are up
      03-03-2013, 10:05 AM   #2
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
Don't think Megan has applications for the xi
      03-03-2013, 10:50 AM   #3
zipstic
484
Drives: 2008 e92 335xi
2008 335xi Coupe  [10.00]
There aren't many "cheap" suspension options for xi/x-drive. Generally speaking you get what you pay for with your suspension setup. I would recommend the V1's, but if you're really set on saving money you could cost out a spring and shock combo like eibach and koni's. Some people have put on only springs and hated it so I would avoid that. You can put on spacers with no problems.
      03-03-2013, 02:20 PM   #4
aadum
aadum's Avatar
Croatia
80
Drives: 330xd e92 ,520d f10, 540i G30
i had spacers on my 19'' 3 cm on each side...they where rubbing but rear tyres are 275 and wheels are 9,5 ... Do not worry on 18'' it will not rub... Even if they do you cand adjust angle of your rear wheels to get "stanced" look
      03-06-2013, 08:04 PM   #5
Cuba
Cuba
Cuba's Avatar
81
Drives: 07 328xi
Honestly theres not too many options for our xi cars. I picked up a set of used kw v1's with 4k miles on them for 800. running a 9.5" rear tire with +30 offset then added a 10mm spacer and theres barely any rubbing, only on big dips. So i think youd be fine. I would recommend the kw's they are an excellent coil over
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
      03-07-2013, 07:40 PM   #6
slipaway37
slipaway37's Avatar
83
Drives: '13 ZCP/E92/M3
If you can afford it, go with the KW V3 setup because it's adjustable and rocks. I luved my setup.
Now it's time to lower my M3!
'13 Frozen Grey, ZCP/E92 M3. Expel Stealth PPF; BPM Stage II; Macht Schnell Stage II intake & pulleys; Brembo 380 BBK; Gintani x-pipe w/4 resonators; Akrapovic slip-on; RD springs.
'16 Porsche Cayman GT4: No MODS required, lol.
      03-07-2013, 08:43 PM   #7
Goldenc717
Goldenc717's Avatar
Drives: 2007 E90 335xi
This is my before and after shot attached. H&R coilovers lowest setting. 19x10 +37 rear and I still have room for probably 15mm spacers.
      03-10-2013, 09:05 AM   #8
SyL3nTFoRcE
64
Drives: 2008 335xi
UPDATE:
Ok so i pulled on the trigger on KW V1 i found a set used less than 3000 miles locally form another XI owner so those will go on i was think 15mm rear and 10mm front? any thoughts on that i wouldnt want to rub so i was even think 10mm rear and 5mm front if possible.
Any help will be appreciated
      03-10-2013, 10:26 AM   #9
asianstutter
Drives: 2006 BMW 330xi
Originally Posted by SyL3nTFoRcE View Post
UPDATE:
Excellent choice! I will be installing my kw v1 in couple of weeks as well as my 15mm spacer for the rear only.
      03-11-2013, 02:29 AM   #10
949Banker
Drives: E46 JB M3 Vert | E92 AW 335Xi
out of curiosity, aside from kw suspension and h&r coilovers...who else makes coilover systems for the xi application?
03 Jet Black E46 M3 Vert || 08 Alpine White E92 335xi
MFest || TheSHOP || STM || Southbay Autohaus || EAS
AG Forged || StilundMacht || BavX || Hardware Motorsport || Team Leche
      03-11-2013, 06:01 AM   #11
SyL3nTFoRcE
64
Drives: 2008 335xi
i was thinking about doing the rear only but in my opinion the fronts need to poke out a bit more also
not so many from my knowledge i think st and megan might have them also anyone care to chime in
      03-11-2013, 06:18 AM   #12
NJE90xi
Drives: 2007 E90 xi Sedan
+1 for the V1's. 10 mm spacer in front and 15 mm in rear.
      03-15-2013, 04:15 PM   #13
Shinzi
Drives: 335XI
V1's... I just installed mines. Took me and a buddy about 4 hours. But its well worth it. LOVE EM
