BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Suspension noise over rolling bumps
      02-25-2013, 12:57 PM   #1
f0xfire021
Drives: '09 e91 328xiT | 6mt
Over the last few weeks I've noticed a metallic "kachunk" noise when driving over low-frequency bumps. These bumps have been a combination of rolls in poorly maintained roads, entries into driveways and ice ruts. It's happened at speeds between 10 and 40 mph, and as I'm rolling over a bump, the suspension makes a creaky, metalic thump sort of noise - almost like it's fully unloading the springs on the backside of the bump. It's not a knocking noise as far as I can tell.
In the last several months, prior to hearing this, I had hit several ice-ridges on local freeways at 65-70 mph that were severe enough to bottom out the suspension and induce profuse swearing. Not sure if there's a direct connection, although those impacts probably can't be good for the car.
Anyone else have this? Should I be concerned? Car has 51k on it. Thanks.
      02-25-2013, 02:54 PM   #2
mike-y
just another bmw douche bag
195
Drives: 1.9L of fury
check the strut top nuts.. might not be the problem, but it's a really easy fix if it is. Make sure they are tightned down all the way.
      02-26-2013, 07:36 AM   #3
W.WCherry
35
Drives: e92
I had a similar problem. Turned out to be a sway-bar end link.
Performance |Dinan Stage 3 Software|Dinan IC|Dinan OC|UUC/Corsa Exhaust|Koni FSD Shocks and Struts|Eibach Spings|Hotchkis Anti Sway Bars|6MT|Style |Aero Lip|Aero Rear|M3 Spoiler|BMW Gloss Black Kidney Grills|BMW Aluminum Pedals|BMW LCI Tail Lights|HID Fog Lights|25%Tint|Advan AVS Model F7 19" Rims|Lux V3 AEs|Premium|Sport|Comfort Access|
      02-26-2013, 09:53 AM   #4
f0xfire021
Thanks for the input guys. I'll take a look at the strut tops, and check the sway-bar, as well.
B.Corso - was it an issue of the link being loose and needing to be tightened, or actually failing?
      02-26-2013, 10:09 AM   #5
Blackhawk36
Blackhawk36's Avatar
30
Drives: 2007 335i 6MT No iDrive
The link is a 6 inch long rod between the sway bar (mounted above the rear axle) and the suspension. It is unlikely to come loose and it is very common that it wears out.
      02-26-2013, 03:45 PM   #6
khaye1
khaye1's Avatar
Philippines
145
Drives: 18 AW F80
top strut nuts, like the others have said...cheapest, easiest solution.
