Bmw 320si Race Car Build
02-24-2013, 02:49 PM | #1 |
Rep 29
Hi E90 Post
Ive Been Building A 320si Race Car For The Nurburgring And Im Thinking Of Posting The Build Process Is Anyone Is Interested ? Last edited by bmw vln; 03-01-2013 at 04:28 PM.. |
02-24-2013, 02:53 PM | #2 |
Turbonator
22
Rep 261
Drives: E92 335iS
hell ya!
(<OO\ (III] [III) /OO>)
02-24-2013, 03:04 PM | #4 |
Rep 277
Drives: '11 E90 N52 6MT
As much detail and as many photos as you can, I wish I had documented the e36 transformation so seeing an E90 would be great!
02-24-2013, 04:03 PM | #7 |
Rep 75
I would be very interested in a build thread! Count me in
2008 E83 X3 3.0si 180k
2006 E90 330i | Black Sapphire | ZPP | ZCW | NO Turbos! Retired 2002 E46 330i 297k Retired 2000 E46 323i Retired S9 Posted |
02-24-2013, 04:56 PM | #8 |
EL JIMMY NEURON
44
Rep 1,180
Fuuuuuu!
Sub'd
2007 Jet Black E90 328i
Thread: http://www.e90post.com/forums/showthread.php?t=825249 Instagram: manutd_as |
02-24-2013, 05:02 PM | #9 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
No, don't post.... people on here hate seeing awesome track car builds
(sarcasm, as much as you can give us!)
02-24-2013, 06:51 PM | #10 |
Rep 29
320SI SPEC
Hi E90 Post
Thanks For Your Interest I Will Get All The Pics Together And Start A Post Soon Here Is Some More Info For Now Bmw 320si Spec Custom Cages T45 Lightweight Roll Cage Tig Welded Corbeau Revenge Carbon Kevlar Seat Size M Hans Compatible Schroth Endurance 6 Point Harness Schroth Window Net And Fitting Kit Sparco Steering Wheel With Lifeline 8 Pin Detachable Steering Boss Race Tech Dash Mounted To Wheel Race Tech Video 4 With Gps 2 Camera System F.e.v Fire Extinguisher Super B Lithium Battery 1.6kg Armtech Battery Isolator Carbon Door Cards 1.2mm Carbon Center Console Carbon Drivers Floor Carbon Footrest E9x M3 Front Control Arms E9x M3 Rear Upper Arms Lower Rear Arms Strengthend Turner Delrin Rear Subframe Bushes Turner Delrin Diff Bushes Powder Coated Subframe (gray) 4 Way Intrax Coilovers With Black Titan Coating Remote Res And Race Top Mounts Fully Adjustable H & R Anti Rollbars Diff Cooler With Black Fittings And Lightweight Black Hoses Mocal Filter Oem Disc And Calipers With Endless Endurance Pads Endless Brake Fluid Compomotive Mo6 Wheels 8 X 18 (3 Sets) Last edited by bmw vln; 02-24-2013 at 08:38 PM.. |
02-25-2013, 04:56 PM | #16 |
Rep 29
320si VLN build
Ok this is going to take a week or two . do i just edit this post or should i start a new one. may sound stupid but this is the first forum ive ever used.
02-25-2013, 05:06 PM | #17 |
Rep 211
Drives: 2011 r56 non-s
Omg, I thought you weren't serious until I saw your third pic. Nice
Current: 2011 Mini Cooper R56 MT 'Justa'
Previous BMWs: 2008 E92 328i MT Sport / 2005 E83 X3 2.5i |
02-25-2013, 05:15 PM | #18 |
213
Rep 1,782
Very nice! Are you going to do anything power wise?
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
02-25-2013, 08:04 PM | #20 |
I have to return some video tapes
362
Rep 4,712
very interested
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
02-27-2013, 08:55 PM | #21 |
Rep 29
320si power
02-28-2013, 04:24 PM | #22 |
Rep 29
320si build
Hello e90 post
I am going to make a start on the build process of my bmw 320si. The car was built for the VLN series in Germany there are 10 races all of which take place at the nurburgring. Each race is 4 hours long with one of the races being 6 hours long and most cars have 2 drivers some 3, but you can do a 4 hour race by yourself if you think your fit enough. There are 2 main types of race car that run with over 200 cars in total. the first type are production cars that have strict rules on what you can and cant do to your car these are called V class cars and are categorised by engine size all are n/a V1 up to 1600cc v2 up to 1800cc V3 up to 2000cc v4 up to 2500cc v5 up to 3000cc v6 up to 3500cc V class rules are there to make motorsport at the Nurburgring more affordable. The second type of cars are called SP these include z4gt3 gt4 cars 911 rsr and lots more. here are some of the regs V class regs * no more than 5% increase in power from standard figures * suspension is free but you can not change the mounting point locations *standard size discs and standard calipers, pads are free *standard gearbox and diff *all bushes must be none metallic so no aluminum but poly or delrin is fine * tyres are free *no more than 70 liters of fuel *no air jacks hope this helps you understand why some things have not been upgraded on my car. OK time for some pics wish i had taken many many more, any questions please ask. Last edited by bmw vln; 02-28-2013 at 05:28 PM.. |
