02-19-2013, 12:36 PM | #1 |
Newbie: quick learner
Rep 24
702 bhp from a remap?
Hi guys, 1st post!
I bought a 5k mile frozen white f10 m5 last week and decided to get it mapped by a tuner that I have used on my diesels in the past. Here's the before, at staggering 636bhp out of the box? And here's the after, an even more staggering 702bhp- an 86bhp,increase Is his rolling road badly calibrated or is this possible?... Thanks chaps, Martin
2010 Land Rover Discovery HSE in white
2008 Techart 997 Turbo Cab- 650bhp in black 2009 Yamaha R1 in black and gold |
02-19-2013, 12:56 PM | #2 |
19242
Rep 10,146
634 bhp seems a bit high---- Ive pulled 551 whp (uncorrected) which would translate into the 600's at bhp but I dont know our true drive train loss percentage with the DCT.
How is that dyno adjusting up for bhp- whats the percentage adjustment? I do like your gains though as those are relative to the before and after numbers.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
02-19-2013, 01:50 PM | #3 |
Rep 24
I don't know the answer to how the dyno adjusts and am not mechanically minded.
The power gain was definitive and impressive and I'm very happy with the job. I love the idea of 702 just didn't/don't want to kid myself and mug myself off telling people....
02-19-2013, 02:15 PM | #4 |
37
Rep 211
Great results.
I am Uk based and plan on using Evolve but what are your thoughts after the remap (how does it put the power down etc)? It's the real world results that really count although agree that it is nice to know your not spouting s@@t when discussing with others! |
02-19-2013, 02:23 PM | #5 |
152
Rep 3,041
As much crap as this is going to stir, on very good authority I can tell you that pretty much every dyno result anyone has posted is utterly bogus.
With the F10 you must log the ignition timing curve, air intake pressure (must be 1:1 which NO ONE is doing), and RPMs and then match them to the proper tables. Nonetheless, the simplest of the variables always ignored due to the limiter is that the car must also be run 1:1 in 5th gear. In Europe, a dyno run will void your warranty on the F10 M5. Not sure I would press my luck further in the US. Like I said, I know these comments will ruffle a lot of feathers but so be it. Regardless of anyone's belief or opinion, this information comes from an individual who frankly knows more about BMW turbo cars than ANYONE in the world. Do NOT allow anyone to try and hack your F10 ECU(s). Cannot be done. This is not an E60 any longer. Last edited by ColdList; 02-19-2013 at 02:40 PM.. |
02-19-2013, 04:25 PM | #6 |
Rep 24
Coldlist, now I don't understand your post?
My car was remapped via the obd port under the steering wheel, I was there. My post was how realistic the power outputs were? I can 'absolutely & categorically' tell you that the car is substantially more powerful since its been remapped, the exhaust now pops and bangs which I didn't notice before also.
02-19-2013, 06:11 PM | #7 | |
152
Rep 3,041
I can also tell you categorically that if your Dyno tech is not following the logging and comparing and comparing against norm values as described above and that the wind into the car is not at a 1:1 ratio as well as the 1:1 running in 5th gear (which I know is not happening without a Euro limiter, which is not available yet her in the US) that your Dyno results are grossly unreliable. Again, this is not a typical car that you can just put on a Dyno and set a simple SAE adjustment. The engine management system is way too sophisticated for there to be reliable results produced. Last edited by ColdList; 02-19-2013 at 06:26 PM.. |
02-20-2013, 04:19 AM | #8 |
35
Rep 168
This is impossible, next time you go there, put it on 5th gear and dyno test it again. Because the 1:1 ratio is on 5th gear. If you run it under 5th, ull get BIG numbers, but not real.
02-20-2013, 07:34 AM | #10 |
152
Rep 3,041
I need to make a correction. I did not see your location. My bad. Being that you are in the UK, it is entirely possible that you have received a legitimate tune. There is one software in the world that can be loaded to the car. It is available to a few tuners across the pond and one tuner here in the US. As for the Dyno, I stand by those comments. I cannot be accurately measured any other way than mentioned.
2016 McLaren 675LT - Chicane Grey 2016 Corvette Z07 - Artic White 2016 BMW F86 X6M - Black Sapphire Metallic |
02-20-2013, 05:10 PM | #11 |
Rep 24
Ok, it's quicker as a result of a visit to DMS automotive in Southampton, UK. End of.
02-20-2013, 05:28 PM | #12 |
Rep 49
Great resut 84H - I had my 1M done by DMS and it is nght and day difference to standard. Also not picked up by BMW during service, etc..
F10 M5 arriving next month, soon to visit Rob again at DMS 703bhp hopefully |
02-20-2013, 08:24 PM | #13 | |
152
Rep 3,041
As for the UK tuning shop and results, it is highly likely if they are using the OBD tune (which it appears they are) that they have the software I am talking about. I could easily verify this and am certain it must be the same tune. There IS only ONE that can be loaded to this car. A few outlets by the same distributor in Europe and one tuner in US who has the software. I am giving you guys DEFINITIVE FACT. Choose to "believe" what you like. I am absolutely correct. Last edited by ColdList; 02-20-2013 at 08:31 PM.. |
02-20-2013, 08:29 PM | #14 |
152
Rep 3,041
COMPLETELY believe you. Per my last two posts, I am highly certain that you are running the same software I am speaking about. As I said, I did not note your location when I made my first post. I run it on mine as well. Significant difference. I am adding the downpipes and performance exhaust shortly (ordered today). If you are interested in those PM me. They are a perfect compliment to that tune. Downpipes delete the 400 cell secondary cat and swap the primary 600 cell with a 400 cell. Exhaust changes the 65mm interior dimension to 85mm. Minimal hp pickup with the exhaust but an improvement nonetheless. Between 30-40 hp gain on the downpipes.
02-21-2013, 01:41 AM | #15 |
Rep 20
@ColdList
Can you give me some numbers, what your gains are for the tuningfile? I can't send you PMs regarding my numbers of postings (3 needed and I'm working on it). Greetings, Phil |
02-21-2013, 08:10 AM | #16 | |
152
Rep 3,041
I do not have an accurate Dyno per everything I said above. You can very easily get tuning information from Manhart Racing in your neck of the woods. They have a valid software, downpipes, etc. Last edited by ColdList; 02-27-2013 at 01:45 PM.. |
02-21-2013, 08:42 AM | #17 |
Perennial PFC
336
Rep 1,274
[QUOTE=ColdList;13506928 In Europe, a dyno run will void your warranty on the F10 M5. Not sure I would press my luck further in the US.
Do NOT allow anyone to try and hack your F10 ECU(s). Cannot be done. This is not an E60 any longer.[/QUOTE] I have no experience with dyno runs, but saying that BMW will void your warranty if the M5 is run on a dyno seems odd. Who at BMW has told you this? Can any of the European owners chime in to say their dealer has advised them that this is true? How can BMW tell that your engine has done pulls on a dyno? From what I've read I do believe that BMW has put more tamper protection into the DMEs and it will be more difficult to modify them. But, you know it will be done eventually, and isn't the tune you are running proof of that? Hoping to learn from your more informed experience, thanks. |
02-21-2013, 09:34 AM | #18 | |
537
Rep 1,157
Bish |
02-21-2013, 09:48 AM | #19 |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
I had same thought.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
02-21-2013, 01:00 PM | #20 |
Internet Crash Test Dummy
331
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
Putting the car on the dyno won't void warranty.
As always if you do something stupid (over-rev, tampering etc) you'll have to consider the consequences. Also repeating the same stuff over and over again doesn't make it any more truthful/credible but I guess on the Internet everyone is an M engineer or attractive blond...
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
02-21-2013, 01:57 PM | #21 | |
187
Rep 1,548
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
02-21-2013, 02:13 PM | #22 | |
152
Rep 3,041
