The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Any issues with 10inch wide wheels on all for corners?
      02-17-2013, 09:12 PM   #1
2JZ-GTE
Drives: Tracked E46 M3
Does anyone have any experience or know if 10 inch wide wheels with an offset of +25 will work on all four corners for a 2009 335xi? Was thinking about 245s for tires? Stretched out look of course.
The car is lowered with coilovers.
      02-18-2013, 06:19 PM   #2
wdeerfield
A family of bimmers
2747
Drives: '18 G01 X3M40i
10s i believe only fit the fronts of m3s. Why not do 9s with a 245?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      02-19-2013, 02:51 PM   #3
_shim
147
Drives: an e90
Square 10" setups have been done before. e90, or e92? Either way, a search should give you a few ideas to work with.
      02-19-2013, 04:08 PM   #4
bimmerlicious
bimmerlicious's Avatar
Drives: 08 E92 335xi
I think it could work with stretched tires, let me know how it goes i am interested going from 19x8.5/9.5 to all 9.5
      02-23-2013, 09:01 PM   #5
NJE90xi
Drives: 2007 E90 xi Sedan
Quick question: why the square set up? Unless you want to rotate, the staggered set up works very well on our cars.
      02-24-2013, 09:52 PM   #6
2JZ-GTE
For Rotation and for track days to give the car better balance and more over steer for hard cornering
      02-25-2013, 03:18 PM   #7
elinstylez
elinstylez's Avatar
269
Drives: 2011 e92 M3
You could probably do it with rolled fenders and a lot of negative camber.
      05-24-2013, 02:47 AM   #8
uaizaz
uaizaz's Avatar
Drives: 335xi
2012 335i  [0.00]
2007 BMW 335xi  [0.00]
Hi guys, fairly new to the forum. Question for you... I'm considering going 10.5 rear and 9.5 front. Pretty standard yes, I know but here's my question, I have an xi and like all enthusiasts hate under steer which admittedly there is some times too much on our xi's. So be having 10.5 would I be making things worse for myself in terms of under steer?
