BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Disable Light System Failure?
      02-12-2013, 02:07 PM   #1
vexvi
Drives: 2006 325i
Hello all,
After i installed my HID system. I got two warnings on my display.
1. low beam error
2. red Car on jack (CC-ID 231 Light System Failure)
I was able to disable the warning message for the low beam error and it fix that issue
But i can not correct the second warning light. If i go to the service section (basically the place you can reset your oil and so on), it shows that everything is good.
any ideas??
      02-12-2013, 07:36 PM   #2
rich123321
rich123321's Avatar
72
Drives: BMW 325i E90
2015 335i  [0.00]
Originally Posted by vexvi
Not sure but can it be my FRM?
You have to code the correct voltages I believe
      02-13-2013, 12:26 AM   #3
vexvi
Drives: 2006 325i
thanks for the reply! i was able to solve the issue
      02-13-2013, 06:24 AM   #4
cn555ic
cn555ic's Avatar
441
Drives: 335i
Well for those that have the same issue, Posting your were able to solve it is great and all, but you should post how you fix it and what u did.
      02-13-2013, 05:20 PM   #5
vexvi
Drives: 2006 325i
absolutely! Updated this post. I have narrowed the issue to being one of my HID's. not sure if its the ballast that caused that error but i will update my findings
