02-05-2013, 11:06 AM | #1 |
16
Rep 101
Tire Setup for track or autocross
It seems like there are a few people that have started tracking or auto-x their car. I thought it would be helpful if people provided some information on their setup.
For those that had your car on the track or autocross course, what tire setup are you using? Can you please specificy for the following; Track or Autocross: Size of tire: Brand: Model: Pressures front: Pressure rear: Rim size: Offset of rim: Opinion on tire performance: Hopefully I will be able to provide some feedback in a couple of months when I get my setup. |
02-05-2013, 01:40 PM | #2 |
67
Rep 210
I plan on running in NASA TTD with Nitto NT-01 235/40/17 based on my projected set up. I don't really autocross so I can't recommend the proper tire pressures for that. However, on track, from prior experience, I usually run between 38-40 PSI hot; if I need more rotation, I will back off a little up front and/or increase pressure behind. My wheels will likely be either 17x9 or 18x9, squared set up. I'm not sure on off set.
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 |
02-05-2013, 03:09 PM | #3 |
16
Rep 101
I just ordered my rims and tires today so I'll be able to contribute to my own thread soon.
For reference, I ordered TR Motorsports MT1 18x8 with Hankook RS3's in a 235/40/18. I just dropped 13lbs/per front tire and 15lbs/per rear tire! That's 56lbs in rotational mass! Should be pretty awesome. |
02-05-2013, 04:43 PM | #4 |
918
Rep 2,710
Drives: MB E350 4MATIC Estate
I'm going to run a square set up with Apex 18X8.5 wheels and Hankook RS3 tires. I noticed a lot of cars using these tires at the two track events I've done so far. I haven't received the wheels yet so I'll give a review at a later date. No doubt they will be leaps and bounds better than the stock run-flats that came on my car!
02-05-2013, 06:58 PM | #5 |
67
Rep 210
Those wheels are lightweight and will look awesome. Nice choice.
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 Last edited by JMK007; 02-06-2013 at 07:11 AM.. |
02-05-2013, 08:39 PM | #6 | |
99
Rep 1,050
I also have an F30 that I will be putting APEX EC-7s on. You can run a 245 if points allow it and TC Kline says a 255 square on the F30 is very doable. I work at APEX and we will be doing some fitment testing on the F30 to see what the maximum width fitment is, with and without modifications. |
02-05-2013, 08:49 PM | #7 |
67
Rep 210
The F30 328i starts in TTD. I ran the Nitto NT-01s on my prior e36 M3 as well, but in TTD. I'd be currious to hear what you guys come up with as the widest set up for the F30. I suppose it depends on whether you have camber plates and/or run spacers. Also, certain coilovers may give you more room inside.
02-06-2013, 09:04 AM | #9 |
54
Rep 453
I ran Moda MD15 in 18x8 with Hankook Z214 C51 compound r-comp's in 245/40-18. The tires were leftover from my Evo X. Two are corded due to the lack of negative camber in front so I need to decide what to do next.
I will probably run nt01 next as I can drive to/from the track on that tire. With the Hankooks you really don't want to drive them on the street!!! |
02-06-2013, 09:55 AM | #10 |
67
Rep 210
I really wish Vorhshlag and/or Ground Control would come out with camber plates soon for the F30. Otherwise, we are left with street tires or r compounds that cord easily. I think I will create another post on here about camber plates and, with the help of others, come up with a list of people interested in them to coax these manufacturers.
08-07-2013, 04:49 PM | #11 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Thought I'd revive an old thread rather than start a new one...
jbass524, what's the verdict on the your research for fitting the widest wheel/tire combo on the F30? I've been trying to decide on a wheel/tire combo, but was leaning toward something for all around use as well as track...and also toward a staggered setup. Two questions: Is a staggered setup (say, 8.5"/245mm and 10"/275mm) a compromise on the track? (probably for autoX, but I am mainly interested in track) Also, would it be worth getting a little more width up front (9" wheel as opposed to an 8.5" wheel) even at the cost of a few pounds of weight penalty per wheel?
Ahead of the curve for specF30
08-07-2013, 07:41 PM | #12 | |
99
Rep 1,050
There's a fitment article here: http://www.f30post.com/forums/showthread.php?t=874148. A heavily staggered setup like this, 8.5"/245mm and 10"/275mm, is not good for a BMW on the track. You would do much better with 8.5" front and rear. Just because you can fit a wide tire doesn't mean you should. The reason for the same sizes - square setup - is that BMWs are a little heavier in the front (nothing like an AUDI) so they need every bit as much rubber up there as they have in the back. BTW, a square setup is the best handling mod you can do and should be the first one. The next handling mod should camber. Here's an excerpt from the above linked article: Benefits of Negative Camber[/SIZE]JMK007 and I have both taken our F30s to the track and we both drove them hard. He has a review of his and I think I posted my thoughts also. I won't be competing with mine but JMK007 will. He and I have talked on the phone and I can see he knows what he's talking about and I would pay attention to what he has to say. |
08-07-2013, 09:38 PM | #13 |
558
Rep 1,477
Drives: 335i
Thanks for the very helpful response!
So I'm thinking I'll take the advice of the track guys and stick to a square setup. As much as I like the looks of the wide tires and deep concave wheels in the back, handling is more important to me than looks. I'll read through the fitment link you posted; I trust that info on how much camber is needed to make 9" wheels and wide tires fit up front is in there. In terms of camber for f30s, I haven't seen too many options yet... I guess lowering will add a few tenths of a degree, and I've read that there are oem replacement knuckles that add 30min (-0.5deg). Would that be enough to fit a 9" wheel and a 255mm tire (or at least a 245) without any rubbing?
08-08-2013, 10:40 AM | #14 |
162
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Front 245's fit no problem, both on stock suspension and lowered on H&R sports
I autocross the car regularly and there is no evidence of any rubbing on the tires or the fenders 255's are probably doable on the front, but it's going to be close. A little camber adjustment (when that's available, or the OE swivel bearings) or maybe just the right offset would make it no problem I find the 245 re-11a's to have good grip and square to give the car nice balance. The H&R sport springs also made a significant improvement to the handling and feel of the car, as did a proper alignment I also hear great things about the new BFG Rivals, great grip, very progressive and phenomenal wear - I will likely try those next |
08-08-2013, 12:10 PM | #15 | |
99
Rep 1,050
The F30 seems to be very sensitive to circumference. |
08-08-2013, 12:15 PM | #16 |
162
Rep 573
245/40/18 - the diameter variance is < 1% different - tread-depth wear will affect the circumference more than this variance from stock
08-08-2013, 12:53 PM | #17 |
99
Rep 1,050
08-08-2013, 01:43 PM | #18 |
162
Rep 573
Stock 18x8 sport line wheels.
Believe the offset is 34, but don't quote me Going to get some oz HLT wheels when I need new tires |
08-08-2013, 07:23 PM | #19 |
649
Rep 4,323
Stock S001's!!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
08-13-2013, 02:33 PM | #20 |
BimmerPost Supporting Vendor
3519
Rep 6,701
Upon reading this thread we saw a few comments regarding tire sizes in regards to rubbing and would like to chime in with information regarding the F30 wheel and tire fitments.
The OEM F30 Sportline wheel is 18x8" ET34, and the EC-7's are 18x9.0" ET42. The EC-7's extends an additional 5mm on the fender side, while it takes up an additional 21mm of clearance on the strut side in comparison to the Sportline wheels. Also, since the EC-7's are an inch wider, this means that they are approximately 12.5mm wider per side of the wheel (half an inch wider per side of the wheel) than the OEM Sportline wheels. What this means is that using the same tire on the two different wheels will have different results, as the sidewall characteristics of the same tires will be different between the different width wheels. This may be the reason why some have not experienced rubbing issues with the 245/40/18 tire size. Using the 245/40/18 tire on the 18x8" ET34 wheel is oversized, and due to the tires being ballooned with a narrower wheel, the tires effectively become ~240/40/18 since the tread is pulled in as the tire bead is pulled in. This happens when a tire is mounted on a wheel that is too narrow. Additionally, there would be less sidewall support from a wheel that is too narrow creating sloppier sidewalls, which in turn causes steering response to be less nimble and makes it more difficult to drive a tire at its limits. For street use this may not be an issue, but if one is looking for performance we do recommend the proper tire size and wheel width combination.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
08-19-2013, 10:58 PM | #21 |
205
Rep 7,298
I literally went to a bmw cca autox event for the first time ever in my life in my no line 328i with crappy runflat 17" all seasons and i got 2nd place in the turbo stock class which included n54/55 engines (335i, 135i). You dont need any upgrades, you just take your car there and drive the snot out of it. When you no longer have grip because of your skill set, you get wheels and tires.
08-20-2013, 12:48 PM | #22 |
162
Rep 573
I took measurements when the wheels were off the car yesterday
Section width 9-5/8 (Tire Rack shows these as 9.8" on a 8.5" wheel. Bridgestone suggests 8-9.5" rims for this tire) Hub to inner section 6-1/8 (i.e. lay the tire down, put a straight edge across the tire, measure to the hub) In the front, the inner restriction is the strut Hub to strut 6-5/8 (put a straight edge across the hub, measure up the distance of the widest part of the tire, measure into the strut at that point) So there's 1/2" clearance on the inner side in the front with this setup. |
