TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Engine ticking
      02-04-2013, 03:49 PM   #1
MJ
MJ's Avatar
Drives: Blk on blk 2007 328xi coupe
Engine ticking
I have a bit of a problem with my engine suddenly ticking. I know it's not the sound of the injectors, I know the difference.
I know this has been discussed on other threads but I have a video from YouTube that is the exact sound of my engine. It is a 2007 E92 328xi.
I have a scheduled appointment at my Bmw dealership for next week but would love some input on what you guys think the problem might be.
Here is the video:
My engine sounds identical...
Any help would be greatly appreciated.
      02-04-2013, 03:55 PM   #2
Sethism
Sethism's Avatar
Drives: 2009 328i Xdrive Coupe
Read the very first sticky at the top of this forum.
http://i1069.photobucket.com/albums/u474/sethdude1/Sig_zpsadfce59b.jpg
      02-04-2013, 03:59 PM   #3
rjrankin83
rjrankin83's Avatar
Drives: 06 330i
Lifters issue?
Mine does it periodically but eventually goes away. My commute is 4 miles and I find if I don't run my engine more than that 4 miles, after a few days it will come back. I've read cold weather will bring it on also. I think the injectors are a "softer" noise
      02-04-2013, 04:02 PM   #4
JuppiOne
25
Drives: everyone crazy
that
      02-04-2013, 08:44 PM   #5
mxchris727
mxchris727's Avatar
193
Drives: '03 M5, '06 325i, '12 M3
No, only the N52 engine had that issue. All 328's have the N53.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
      02-04-2013, 08:51 PM   #6
calicolorado
calicolorado's Avatar
No_Country
163
Drives: F10 M5 Comp 6-spd
2015 BMW M5   [0.00]
1972 BMW 200/  [0.00]
2020 BMW X7 40i  [0.00]
Actually, in the US, we didn't get the N53-that was the direct-injected, normally aspirated 6 that the Euro 330i had. 272bhp, I believe! US 328i's have only the N51 and N52 engines with good, old fashioned port fuel injection.
My car has the N51 and it does tick very occasionally at cold startup if I've been only driving it on short (1-4 miles) trips.
I wish we had gotten the N53 in the US as it would have been a perfect in-between twixt the 328i and 335i...
2015 M5 Comp 6-spd manual
1972 2002
2003 Audi TT Coupe 225
2011 Highlander 4WD
      02-04-2013, 09:09 PM   #7
ctuna
1915
Drives: 325xi 06 wagon MT
I wonder if the n53 suffers from intake build up?
I wonder if the n53 suffers from intake build up.
Or is it enhanced by the Turbo's?
      02-04-2013, 09:28 PM   #8
Sethism
Sethism's Avatar
Nope. North American 328 models have the N52.
      02-04-2013, 09:35 PM   #9
nogard13
nogard13's Avatar
34
Drives: 2006 325i
Normal. Just drive it like you stole it for 5-10 mins and it goes away. I normally take it on some back roads by my house and put it in manual mode. I make sure to accelerate it to ~6500RPM before shifting, and I do it for about 5 minutes. After that, the ticking is gone for a 7-10 days.
      02-04-2013, 09:37 PM   #10
manutdas11
EL JIMMY NEURON
manutdas11's Avatar
44
Drives: Jet Black E90
2007 Jet Black E90 328i
Thread: http://www.e90post.com/forums/showthread.php?t=825249
Instagram: manutd_as
      02-04-2013, 10:03 PM   #11
mike3000fl
No_Country
138
Drives: 06 330i
welcome to the party.
      02-05-2013, 12:07 PM   #12
shapptastic
Drives: 09 e92 335i
Not necessarily the case, but with me the ticking noise was due to the serpentine belt and associated pulleys failing. I would check that before it fails, it's a cheap repair.
      02-06-2013, 01:16 PM   #13
MJ
MJ's Avatar
Thanks to everyone for your input.
I thought the reply about the serpentine belt was interesting as I had some weird screeching noise come from under the hood once.
Also I talked to a Bmw serviceman and he said because my car was off the road for the last few months that it may be a hydraulic lifter that needs to get enough oil pressure beneath it to "pump it back into position". That actually sounds logical to me.
I guess I'll find out next week when I take it in.
Again thanks for everyones help...
      02-06-2013, 01:17 PM   #14
Delta0311
7478
Drives: 2011 BMW 335xi E92 2016 228xi
Replace Head
Replace Lifters
Problem solved.
      02-06-2013, 01:23 PM   #15
trk06
trk06's Avatar
24
Drives: with no spare
What kind of fuel are you using? Low octane fuel will cause ticking noise as well.
      02-08-2013, 11:26 PM   #16
jerky969
Drives: 2007 328i
Here is the video:
I have a 07 328 and have this problem. Dealer replaced lifters once , that was a year after I bought the car under warranty
      02-08-2013, 11:26 PM   #17
jerky969
Drives: 2007 328i
Here is the video:
Didn't fix the problem.. Ticking came back soon after
      02-09-2013, 03:50 PM   #18
bumere90
Grozniy
177
Drives: Carless
live with it
      02-09-2013, 04:22 PM   #19
BOBKUR
20
Drives: 2008 E 90
ULEV engine is N52
SULEV engine is N51
      02-09-2013, 04:31 PM   #20
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
1113
Drives: 2011 335 E93 M-Sport
Common as can be, and completely normal.
      02-09-2013, 04:46 PM   #21
smaxon1
smaxon1's Avatar
Drives: 335is
Originally Posted by Delta0311
Replace Head
Replace Lifters
Problem solved.
Had this done under warranty on our X3.
Problem solved.
      02-09-2013, 05:11 PM   #22
avocet
252
Drives: 2007 328i 2011 X5d
had my lifters changed. dramatically reduced the noise.
since changed my oil to castrol ll-01 5-40 and problem is gone.
just my experience.
