02-03-2013, 10:48 PM | #1 |
Feeling horny
36
Rep 152
Best EQ setting for base speaker
I've got the standard sound system on my f30, I know it's mostly personal liking, but what EQ setting do u guys use with the base system?
Mine is tre +4 bas +5
BMW F30 328i Sport Line
02-04-2013, 03:33 AM | #3 | |
Feeling horny
36
Rep 152
02-04-2013, 05:03 AM | #5 | |
Feeling horny
36
Rep 152
Thanks mate.
02-04-2013, 01:58 PM | #6 | |
100
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
With today's digital music recordings, the quality of the music can vary greatly. What sounds good with one recording, can sound very poor on another. The different bit rates used in creating say MP3 files can vary greatly, resulting in mixed quality from song to song. Also, different genres of music can be recorded differently, resulting in the need to adjust the bass/treble settings. So, how do you set up the base system? To whatever sounds good to you overall or for that particular set of songs. Even with the hk system, different recordings can sound fantastic, while others at the same setting, sound awful. First try to obtain the best possible quality & clarity of music to listen to. There isn't a one setting to fit all formula.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
02-04-2013, 04:28 PM | #7 | ||
Feeling horny
36
Rep 152
Geez, is there anything u don't know. Lol I mostly listens to pop musics. R u on hk? I regret on not getting hk... My bad...
02-04-2013, 07:06 PM | #8 | |
100
Rep 3,566
LOL, sure, there's LOTS I don't know. Seriously. Growing up as a teenager in the '70s, my hobby was hi-fi and I became an electronics technician in the late 70s. Although I don't practice being an electronics technician any longer, my business (video productions) includes a great deal of audio, so I am very aware of the technicalities surrounding this field. Even back in the tape days, there were great differences between tape formulation, (tape) bias eq, tape speed and recorders, which resulted in varying quality as well. Not much has changed from that respect. Yes, my car has the hk and with such an elaborate system, different recording qualities REALLY stand out. Cheers
02-04-2013, 08:40 PM | #9 |
65
Rep 1,549
Ya you tend to get very good quality recordings and very bad ones.. even when i try to stick to 320bit rate mp3.. some of it sounds pretty bad.
P/S- if you're using an ipod or iphone make sure u turn off the equalizer when u plug it in else it will just stack the settings.. it will be hard for u to benchmark your settings in the car. By all means leave the equalizer on when you use your headphones but turn em off when u plug it into ur machine |
02-05-2013, 04:16 AM | #10 | |
Feeling horny
36
Rep 152
02-05-2013, 06:43 AM | #12 | ||
65
Rep 1,549
02-06-2013, 02:18 AM | #13 |
Money never sleeps
15
Rep 336
I will be changing my front 2 speakers out to aftermarket... its a relatively easy task given i've had some experience in the past. anyone thinking of the same??
U just need decent after market speakers flat enough, dont necessarily need Harmon ones. For under AUD100 u'll be surprise at the results |
02-06-2013, 04:30 AM | #14 | |
Feeling horny
36
Rep 152
can u make a post once u get this happenning with photos. I'm looking to do the same.
02-06-2013, 06:15 PM | #16 |
Rep 44
I'm going base system and then spending 1.5k on a much better aftermarket system. LOC, amp, speakers.
I have the Dynaudio system in my golf and it's great value for money. I don't see the HK as being the same. |
02-06-2013, 09:10 PM | #17 | |
97
Rep 473
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned Current - 2019 BMW G20 330i M Sport Alpine White Retired - 2018 - Range Rover Velar SE D240 Retired - 2015 - Mercedes Benz C250d AMG Line W205 |
02-07-2013, 06:12 AM | #18 |
Money never sleeps
15
Rep 336
I know for the E92, the max dept was 28mm... no more than that. and i was pushing it...i can hear the window scrapping it, but lucky no scratches. This time around I will def choose 25mm or less.
Go with an American brands, they tend to have better response for bass, the base in the BMWs really dont cut it. The bass subs are way too shallow and lightweight to dump out decent sound...so we need the front speakers thats all purpose with built in tweeters to cover as much of the frequency range as you desire. |
02-07-2013, 06:14 AM | #19 |
Money never sleeps
15
Rep 336
dont need photos. super easy, just need to pull the interior panel out and then remove the speaker by unscrewing the screws holding it inplace. you will need to soilder after u cut the wire connections.
02-07-2013, 06:37 AM | #21 |
Rep 44
I used to run an sq setup in my old e36. Nakamichi head unit, 2 ch amp powering some morel speakers in the front and a mono for a single 10 sub in the boot in a custom box.
The difference between running good speakers off the head and from an amp is night and day. Not just volume but crispness and clarity. I just finished a similar setup in a golf gti. A small amp to power the fronts really makes a huge difference. The rears are fine to run off the head. |
02-08-2013, 03:50 AM | #22 | |
Money never sleeps
15
Rep 336
