Oem 220m on 335xi , help!!!
01-31-2013, 02:14 PM | #1 |
10
Rep 390
So I bought oem 220m wheels last night with stock 245/35/19 and 265/35/19 and I'm rubbing like crazy , and I hear a ticking clinking noise while driving ... Should I get smaller read tires or is it worse then that
Lowered on h&r race springs |
01-31-2013, 02:50 PM | #2 |
232
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
220M are the E90/92 M3 wheels correct?
From what I've read the aggressive offset on these makes it quite the squeeze for the standard rwd E90/E92 and even more clearance issues for the XI ones.
02-05-2013, 11:19 AM | #5 |
Rep 514
Maybe my math is wrong, but I think those size tires puts a ~2.1% difference in the rolling diameter between the front and rear wheels.
I believe the rule of thumb for our xi cars is to keep it under 1% so we don't stress out the transfer case. The ticking, clinking noise would worry the hell out of me. For a staggered 19" setup the sizes phozenstone posted above would be ideal, or 225/35, 255/30. I think in another recent thread someone was planning to run 225/40, 255/35 which would also be good. Last edited by Kalidian; 02-05-2013 at 11:34 AM.. |
02-05-2013, 11:48 AM | #6 |
2760
Rep 5,483
That rear tire size is too big for a non-M E90/E92. Get 265/30-19's. There is a 0.7" difference in diameter between front and rear, which is not going to do your drivetrain any favors either.
02-05-2013, 12:49 PM | #7 |
10
Rep 390
02-05-2013, 03:42 PM | #8 |
854
Rep 682
Drives: 2023 G80x M3C
02-05-2013, 03:46 PM | #9 | |
854
Rep 682
I will be attempting to put 40 front 35 rear with 19 inch Style 67 M3 rims this summer. But then, I have an xi and am not lowered at all. ALSO, I would be VERY concerned about the noise. Since your wheels are staggered, your front and rear tires cannot be the same height. This will cause a rolling diameter difference higher than 1% which can seriously mess up your AWD. The noise you mention sounds like the transfer case issue to me due to the diameter difference. I would definitely reconsider the tires with the RIGHT size immediately so the diameter difference comes down to recommended numbers. |
02-07-2013, 04:59 PM | #10 | |
13
Rep 599
Take 'em off ASAP or you're gonna jack up your AWD system. |
06-24-2013, 01:42 PM | #13 |
325
Rep 5,370
as long as you are not lowered, then they will fit fine and will not rub. I ran 220's with the same size tires when my Xi was not lowered and it was fine. I recently got KW V1's put on and the rear is a bit too low even with rolled fenders.
