TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Will this wheel setup work?
      01-29-2013, 05:13 PM   #1
Shinzi
Drives: 335XI
Hey, Ive got an 08 335XI Coupe and im looking at this wheel setup and im curious as to if it will work. I am also concerned with it not clearing the brake calipers, as he had mentioned it wouldnt clear his. Anyone have any idea on these wheels?
If I did the calculations right the diff between the front and the rear is somewhere like ~0.2%
F: 18x8 ET 35 225/40/18
R: 18x9 ET 38 255/35/18
http://www.e90post.com/forums/showthread.php?p=13393444
Please, and thank you.
EDIT: Also looking to drop on some KWV1's or V2's if it makes a difference.
      01-29-2013, 05:42 PM   #2
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
Those should fit no problem. what is your concern about the clearence in front with the brake calipers? Are you running stock brake calipers, if so you have no problems. I also have 08 335xi and run 18x8.5 et 35 in front with no issues.
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
      01-29-2013, 05:58 PM   #3
Shinzi
Drives: 335XI
Yea, im on stock brake calipers. He had mentioned he was on the sports ones.
      01-29-2013, 06:07 PM   #4
CT335xi
CT335xi's Avatar
684
Shinzi I think you will be fine. If he's not to far from you may he will let you try before you buy and see how they fit. There nice looking wheels, they look like a bbs or csl style. If for some reason the fronts wont work you can always run a 10 mm spacer to clear the brake caliper, but I don't see that as an issue for you. hth
2014 x5 50i msport
      01-29-2013, 06:17 PM   #5
giaolong
giaolong's Avatar
Drives: E92 335xi, Genesis, IS300
It should fit no problems
Looking at the other thread, seem like the shop that he brought those wheels to is on crack.
09 BMW 335xi e92
-KW-M6 Wheels-Toyo-Mtech-RSD-
      01-29-2013, 06:24 PM   #6
Shinzi
Drives: 335XI
Cool thanks guys. Im pretty new to all this stuff so the offsets and stuff kinda scared me when he told me it didnt work on his.
      01-29-2013, 06:33 PM   #7
CT335xi
CT335xi's Avatar
684
No problem. Post up some pics of them on your car if you decide to buy them.
2014 x5 50i msport
      01-30-2013, 12:44 PM   #8
Shinzi
Drives: 335XI
Will do.!
