19x9.5 front on 2009 E91 LCI - will they fit?
01-28-2013, 12:37 PM | #1 |
Rep 10
Drives: E91 320d LCI / E39 M5
hey guys,
I own a 2009 E91 LCI (facelift). I would like to run 19x9.5 with 35 mm offset on the front. I know rears are no problem. Would it work? I saw some posts about the pre-LCI models but nothing about LCI. I thought only the rear axle was changed on the LCI which permits running anything more than 9.5 without major fender rolling please help thanks |
01-29-2013, 05:56 AM | #2 | |
163
Rep 2,823
01-29-2013, 10:59 AM | #3 |
A family of bimmers
2748
Rep 7,742
seems that et35 puts it really close to the strut even stock. my 18x8.5et40 was really close, couple millimeters away. the 9.5 would be 8mm closer than that.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-29-2013, 11:54 AM | #4 | |
Rep 10
thanks |
01-30-2013, 12:22 AM | #5 | |
163
Rep 2,823
http://www.e90post.com/forums/showthread.php?t=670323
04-30-2013, 02:10 PM | #6 |
17
Rep 263
On a Pre-LCI, if I have coilovers, would 19x9 et35 front clear the struts?
05-01-2013, 05:29 AM | #7 |
163
Rep 2,823
It definitely should. Your clearance compared to stock shock is about 8-9mm that should be enough. I have seen people with 19x9.5 et30 front with coilovers which is 1mm less clearance inside than 19x9 et35.
05-02-2013, 07:43 PM | #9 |
BimmerPost Supporting Vendor
2048
Rep 25,989
^I've seen it done before.
VMR|Wheels | 714.442.7916 |
05-02-2013, 11:04 PM | #10 |
163
Rep 2,823
What does np mean?. But yes 19x9.5 et33 will fit with 235/35/19 tyre. I now have 18x9.5 et30 with 235/40/18.
05-03-2013, 12:27 PM | #12 | |
2048
Rep 25,989
American slang.
05-06-2013, 12:57 PM | #14 |
2048
Rep 25,989
No problem.
12-07-2013, 02:46 PM | #15 |
26
Rep 318
I'm considering runnig 9.5 et32 setup. Would like to run a 245/30/19 tire. I am dropped on eibach. Will this setup rub in your opinions? Where would it rub the fender or the liner?
12-07-2013, 04:42 PM | #16 |
223
Rep 5,120
12-07-2013, 05:42 PM | #17 |
26
Rep 318
Well I allready rub on super tight wheel locked turns with 245/30/19 19x8.5 et35 so... assuming the 9.5 will make it slightly worse. Just trying to figure out exactly how much.
12-08-2013, 12:27 AM | #19 | |
163
Rep 2,823
12-08-2013, 04:14 PM | #20 |
26
Rep 318
You are right 245/35/19. I have a modest eibach drop. It does rub like i said at full lock. I was thinking the 9.5 might help stretch a little too, but it the wheel itself will extend a little bit.
12-08-2013, 09:47 PM | #22 |
44
Rep 243
Drives: 08 PBM 335i E90 w/ sports
Location: Downers Grove, IL or ATL, GA or Asheville, NC
