The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Since you're doing this might as well do that.
      01-13-2013, 11:47 PM   #1
Tonkatruck
Drives: 07 335i E90 Alpine on tan
07 335i 70k auto. Completely stock.
I am going to replace my water pump and thermostat. Also doing oil filter gasket, valve cover gasket and walnut blasting intake ports. I might do spark plugs depending on condition. I think they have 20k on them.
What else, any sensors, any upgrades, change to DCI, just remove the entire engine.
I figure I am saving just about 4 million, taking on the task myself.
Thoughts?
      01-23-2013, 04:01 PM   #2
mi_bimmer
Drives: 2006 325i E90 N52
Tranny and rear differential fluid drain and fill? Recommended at 60K.
      01-24-2013, 09:24 PM   #3
Casca
41
Drives: E90 6MT
Doing my water pump and t-stat too. Decided to do some gaskets and sensors while I was at it.
Originally Posted by Casca View Post
On the same note, I will replace the heat exchanger gasket as well as the oil housing one when I do my pump/t-stat.
http://www.ecstuning.com/BMW-E90-325...skets/ES24026/
Looks like the same type material, so probably the same problems......just not in an area where you notice.
Coming up with a list of different things to do at the same time that requires coolant replacement. So far:
Auxiliary fan switch
http://www.ecstuning.com/BMW-E90-325...ensor/ES34327/
Coolant/Oil temperature sensor
http://www.ecstuning.com/BMW-E90-325...ensor/ES34326/
Oil housing gasket
http://www.ecstuning.com/BMW-E90-325...ensor/ES24030/
Heat exchanger gasket
http://www.ecstuning.com/BMW-E90-325...ensor/ES24026/
Radiator flush
http://www.fcpeuro.com/products/radi...ro-moly-lm1804
Visual inspection of all hoses, clamps and general area and re-service the coolant with OEM coolant......water pump and t-stat replacement to...
