putting sport suspension on an xi model??
01-13-2013, 08:51 AM | #1 |
14
Rep 83
Ive done some searching and can't seem to find it. All I have learned is that the xi models do not come with sport suspension. My question is can you put the sport suspension on an xi model?? (i have an 08 328xi).
Thanks |
01-13-2013, 09:32 AM | #2 | |
226
Rep 2,387
There are a number of various M3 bits that swap too, mainly rear control arms, bushings and such, see the sticky at the top of this section. Short answer if you want "sporty" springs and shocks that are matched on an Xi your best bet is go aftermarket, and that is your only option for front struts. |
01-13-2013, 09:38 AM | #3 |
14
Rep 83
Would it be best then to just put sport springs(h&r, kw, etc) on the stock shocks? I mainly just want my ride lower. It handles great already ha its a bimmer! Im trying to keep cost relatively low as well.
01-13-2013, 10:09 AM | #4 | |
226
Rep 2,387
However if you do go with matched springs and shocks, or even coil overs, it will blow you away how much better it is than stock. Stock IMHO sucks and is one of if not the worst susp ever conceived by BMW. |
01-13-2013, 10:42 AM | #5 |
14
Rep 83
Thanks for the help! I will look into new shocks and springs or coil overs
01-13-2013, 11:36 AM | #6 |
39
Rep 592
Research KW V1s. Sounds like best option for you. I'm looking as well.
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275. |
01-13-2013, 01:56 PM | #7 |
101
Rep 1,036
You can run just the sports suspension springs and car will be lower and handle much better, I was running these until I got my coilovers and had no complains, if you are on a budget throw on some sports springs and when its time to upgrade get kw v1 or v3's.
01-13-2013, 06:09 PM | #8 |
Rep 16
Drives: 2007 BMW 335i
You should just lift it like 3ft and turn it into a monster truck. It would be almost as cool as those lifted Camaros.
01-13-2013, 06:19 PM | #9 |
Waaka Waaka
41
Rep 486
I'm really happy with my KW V1...I'm surprised you think stock handles well. I thought it was simply terrible with civics or corollas being able to corner tighter.
01-13-2013, 06:54 PM | #10 |
14
Rep 83
I used to drive a G35 Coupe and coming from that to the 328 its a HUGE difference. When I originally had the factory rims that were like 16" and 215's all around it didnt blow me away but now having a staggered setup on 18" rims with 225's and 255's(michelin pilot sports) it really handles well! But again Im comparing this to my G35 coupe. I have driven a sport model though and can tell a difference.
01-13-2013, 06:55 PM | #11 |
14
Rep 83
01-14-2013, 08:36 AM | #12 | |
226
Rep 2,387
However it depends on your local roads and driving style, I was bottoming hard on stock Xi. So with shorter not much stiffer springs I can't imagine how bad it would be. Roads are terrible where I live. Cost wise if you are paying someone else to do this you may save money on some used OEM sport springs but end up paying for install & alignment twice when you upgrade to whatever later. Let us all know what you do. |
01-14-2013, 01:57 PM | #13 | |
854
Rep 682
Drives: 2023 G80x M3C
Here is a detailed review/discussion (particularly on the Bilstien Sport + Eiback Pro setup) on an 335xi started by AWD Addict. This should cover all your questions. Good luck! http://www.e90post.com/forums/showthread.php?t=664385 |
01-14-2013, 02:03 PM | #14 |
226
Rep 2,387
Just a note on the Bilsteins, some folks are not pleased with the drop they are getting, e.g.
http://www.e90post.com/forums/showthread.php?t=780476 esp last few posts |
01-14-2013, 02:17 PM | #15 | |
854
Rep 682
So it is a trade-off one way or the other -- something's got to give, right? |
01-14-2013, 02:48 PM | #16 | |
226
Rep 2,387
01-14-2013, 03:18 PM | #17 | |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
Also, you'll end up prematurely wearing your dampers, which will mean you'll need to replace them sooner, and pay again to have the system repaired. At that point, you'll have paid the labor costs twice, only to spend the same money on parts. I would not reccomend just replacing the springs with lowering springs on this vehicle. You should replace both struts and springs together, or go with a coilover option. |
01-14-2013, 03:24 PM | #18 | |
Chief Executive
300
Rep 2,886
01-14-2013, 03:24 PM | #19 |
854
Rep 682
I also read somewhere that you could get the xi to the standard 'i' height by replacing the top hat. So springs + top hat could get a decent lowering.
But like AWD Addict mentioned, it is strongly NOT recommended. Stock suspensions are not designed for lower height and well wear out very prematurely while giving you sub-par handling and comfort. |
01-14-2013, 05:37 PM | #20 |
14
Rep 83
Based on what I've read im getting a better idea on what i want. Ive heard many good things about Eibach pro kit springs but am iffy about putting springs on stock shocks. Im thinking about waiting until my factory springs/shocks need to be replaced and just buy the KW V1 coilovers. Although I'd really like to just buy springs due to cost
01-15-2013, 03:56 PM | #21 |
10
Rep 513
As someone who owns both a 4WD Coupe with S/S and an 4WD wagon I have to ask why you'd want an X with a lower, stiffer setup?
Four wheel drive BMW style is about traction in low grip conditions. That means a softer suspension and in snow, adequate ground clearance. If you want a keener handling BMW go with the RWD and the S/S. Four snow tires and traction control will handle most winter situations. if you're looking for enhanced bad weather grip go with the X. If you try and mix the two you'll end up with something worse than either. |
01-15-2013, 04:37 PM | #22 | |
226
Rep 2,387
A mild drop with a Koni/Eibach or Bilstein/Eibach transforms the car into something that is vastly more pleasant to drive, and handles bad roads far better. Without losing winter or rough road capability. There is more to a good AWD than ground clearance, as the Audi, STi and Evo crowd know. They aren't jacked up into the air. BMW blew it on this suspension, but the rest of the chassis is brilliant. If you haven't driven an Xi with a good aftermarket suspension you ought to see if you can. You'll be pleasantly surprised. It is not harsh at all and feels so much better than stock, a little like an M3 or a tighter, slightly lower, 335i sport. |
