TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d vs 335i
      08-18-2007, 05:22 PM   #1
Craigito
Craigito's Avatar
126
Drives: 16' F82 M4
2020 BMW M4   [10.00]
335d vs 335i
I read that the turbos on the diesel not only are not twin sized but are in series with one another. In fact, it said that after 2500 rpm, the initial smaller turbo does nothing at all.
So why is this a more effective setup on a turbo diesel vs the turbo gas which has independent twin turbos?
Sorry if this has been discussed before.
Previous Ride 2007 335I Coupe / Space / Black Dakota / Gray Poplar / ZSP / ZPP / Step / Paddles / Nav / Hot Seats / IPOD/ Xpel HL
Current Ride 2016 M4 / Mineral Gray / DCT/ Full Black Leather / 19in Gunmetal / Executive /LED/Ohlinds RT/SSR DP-CP-Intake/AP Essex 9668/Bootmod STG 2/DINAN HE
      08-18-2007, 05:43 PM   #2
judec
born to be turbocharged
judec's Avatar
Slovakia
24
Drives: Not a bimmer yet
For the 335d:
it is an effective trade-off of quicker spool-up and low and torque vs. high end performance. In single turbo setup the turbo sizing is very sensitive topic. Put a small turbo in it and U'll spo9ol up quicker and pull from lower rpm, but U'll loose your breath at higher rpm's. Vice versa with turbos too big - U'll be able to compete gasoline engines, but until U get there... ouch. So the BMW sd setup should cure both of those handicaps - 286 HP and absolutely insane torque, BUT - it's not a sports car engine and the 335d is not a sportscar, even if it wears the E92 suit.
On the other hand using such serial setup on gasoline turboed engines would be effective, too, but would be prone to failures due to higher exhaust temps of gasoline engines or I dunno why. Maybe someone wiser could tell us?
      08-18-2007, 05:52 PM   #3
Craigito
Craigito's Avatar
126
Drives: 16' F82 M4
2020 BMW M4   [10.00]
Originally Posted by judec View Post
For the 335d:
Yep..I understand the pros/cons of each setup. I'm just wondering why the same setup wasn't used on both iterations.
      08-18-2007, 05:58 PM   #4
stressdoc
Moderator
stressdoc's Avatar
Dominica
616
Drives: BMW i8; Toy 4runner TRD pro
Might be possible to put two of the twin-sequential turbos on the gas engine. That would be interesting.
      08-18-2007, 08:51 PM   #5
Insider
Insider's Avatar
14
Drives: 2007 335i
The 335i makes 300hp with 8.5 psi boost. The 335D needs 26psi to make 286hp. In order to get 26psi, you need a big turbo. That's why it is setup different. Simply put, diesel engines simply don't make the power of gas engines, expecially in the high rpm area, that's why they need so much boost.
http://www.insiderpicks.com - The world's best stock picks.
      08-18-2007, 11:33 PM   #6
Craigito
Craigito's Avatar
126
Drives: 16' F82 M4
2020 BMW M4   [10.00]
Perfect explanation. Thanks.
      08-18-2007, 11:49 PM   #7
533ogetnom
95
Drives: 335coupe
uhhh...
diesel engines dont make as much power in the "high rpm area" because they DONT HAVE a high rpm area, it makes the same amount of HP at freaking 4k rpms! if it could rev to 7k, jesus christ the thing would be twice the power of the 335
and if you think diesels cant develop the same power as gas engines, try having a conversation with these guys, they will teach you a thing or two
but yea, turbo diesels do need a ton of psi
      08-19-2007, 12:07 AM   #8
Beer Goggles
Drives: 2007 335i E92, 6MT, Sport
The PSI difference is more about the difference in fuel and flash point rather than just looking at how much pressure is needed to make power.
      08-19-2007, 03:34 AM   #9
Panoz
Panoz's Avatar
82
Drives: E92 Space Grey 335i ,Aero Kit
Does the 335d uses the same type of turbos as the 335i ?
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge
Space Grey 335i -> See more pics HERE
      08-19-2007, 03:35 AM   #10
roofer
roofer's Avatar
21
Drives: 335D M Saloon
Agreed.
Depends how you define 'Sportscar' i suppose.
They can be remapped to 340bhp, and over 500ft lLb of torque.
Our roads are better suited to the 'D' i know, but they take some catching.
The biggest problem (for me) is the engine has no soul.
      08-19-2007, 04:58 AM   #11
e.n335
Moderator
e.n335's Avatar
Austria
268
Drives: e93 ///M3 DCT, 07/2009
Diesel Engines
Hi,
The only time I liked my ( chipped ) X5 3.0d has been at the gas station from time to time. Due to the narrow rpm range available you have to shift more often compared to a petrol engine ( the steptronic does this for you ). No top-end power, no engine sound, no higher rpm's. No fun. A diesel makes sense in a big and heavy car like a SUV/SAV. Not in a 335.
My 2 cents.
Cheers
Eugen
      08-19-2007, 07:54 AM   #12
Jerseystyle1
Boris the Blade
Jerseystyle1's Avatar
17
Drives: Montego Blue 335i Sedan
Read above.....
Allan
Montego Blue 335i Sedan w/Navi/Magnetic Black NISMO 350Z #831/76' Mini 1100 "SPECIAL" Export
      08-19-2007, 12:59 PM   #13
judec
judec's Avatar
Slovakia
24
Originally Posted by roofer View Post
Agreed.
the term Sportscar does not necessarily refer to a car with lot of HP/TQ. It needs something more. It's not easy to explain, what exactly - performance? YES. Torque? Yes. Transmission? Yes. Suspension? Yes. Wheels & Tires? Yes + all of this and more complementing each other, packed in a nice package. Now dont get me wrong, nuthing against 335d, it's a really comfortable long distance cruiser, but chipped or not, it's far from a sportscar. That's not dishonesting it, no way, it's just a fact. In fact the 335i also isn't a sportscar, but supported with a few mods it's really close, closer like the 335d.
Search this Thread:
Advanced Search
