12-15-2012, 02:43 PM | #1 |
448
Rep 1,846
alignment needed?
Just went from stock 18 setup to 19" wheels with et32 offset. 19x8.5 et32 235/35/19 front and 19x9.5 et32 rear 265/30/19 rear. No change in suspension. Should I do alignment? Thanks for advice.
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
12-15-2012, 02:56 PM | #2 | |
28
Rep 528
Wow, ET32 would be outer than the fender, am I right? Somebody said you need do alignment, somebody said no, but if you are intended to change suspension in coming future, better do it after your new suspension has installed. |
12-15-2012, 06:46 PM | #4 |
448
Rep 1,846
Yes it sticks out but no rubbing. I will eventually drop it but it will be slight drop. When its dropped I have read on this forum that it will fill fender. Don't know how true it is. I love the wheels but they are aggressive.
12-15-2012, 11:54 PM | #5 | |
28
Rep 528
Do you know how to roll your fender? Maybe can help a bit but it's all depending on how much your wheel stick out. On my ex-E92 335, I have rolled it but still I found the edge of fender too thick, I asked garage to hammer it flat. But in F30, the edge is thin, so you just need to roll it to a bit wider. |
12-16-2012, 01:32 AM | #6 |
448
Rep 1,846
I am going to see if its possible to shave 3 mm of the rears. iND had BBS with 19x9.5 et35 rear and it looks perfect with H&R. If I can do this it would be perfect solution
