12-13-2012, 07:56 PM | #1 |
Supreme Allied Commander
3776
Rep 54,160
Drives: F80 M3
Ohlins Road & Track for your BMW 1M - Worldwide shipping!
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! 2-year limited warranty on all of our products - worldwide. General Features *DFV (Dual Flow Valve) *Rebuildable *Corrosion salt spray tested (ISO 9227) *2 year Limited Warranty Front McPherson Strut *Single bleed adjuster *Spring preload adjuster (approx. 20 mm lower than standard) *Coil Springs (rate 60N/mm) *Height adjustable bottom mount to prevent preloading or unloading of the spring *Dustcovers *Use with original top mounts or camber plates Rear Conventional Shock Absorber *Single bleed adjuster *Separate spring preload adjuster (approx. 20 mm lower than standard) *Coil Springs (rate 110N/mm) *Dustcovers *Use with original top mounts BMZ MN01S1 $3190 Order here: https://hpautosport.com/product/ohli...1m-bmz-mn01s1/ ***We can ship the standard kit worldwide at a very discounted rate. PM us your address for a quote!*** ***Compatible with NEW Vorshlag 1M camber plates*** Last edited by HP Autosport; 09-21-2023 at 01:39 PM.. |
12-26-2012, 11:23 AM | #3 |
3776
Rep 54,160
Drives: F80 M3
02-20-2013, 04:04 PM | #4 |
3776
Rep 54,160
Drives: F80 M3
Ohlins R&T BMW 1M
Ohlins USA will have only 7 kits available out of 15 on March 26th so hurry to your Ohlins R&T dealer today to make your purchase!
05-07-2014, 06:17 PM | #6 |
127
Rep 1,054
LOVE my kit. Single adjustment is definitely no detriment to the performance of the kit.
02-08-2015, 12:39 PM | #9 |
403
Rep 1,620
i want this kit too... i have a couple questions though...
does anyone know if you should also spring for the camber plates or not? i know for track use that is a no brainer... my car won't be a track car. i am just thinking from the perspective of have a nice stance and maybe slightly wider wheels. also what are the spring rates that make the most sense? i drive the car rather 'spirited' on the street. i do race competitively in spec E30 and know how to drive a car hard... but again, i wont be doing that in this. just some fun weekend drives in the canyons and mountains. thoughts?
2023 G80 M3 2020 F87 M2C 2011 E82 BMW 1M Series Coupe Check me out at Point.Shift.Drive (YouTube) |
02-08-2015, 11:35 PM | #10 | |
3776
Rep 54,160
Drives: F80 M3
The spring rates out of the box is perfect for the 1M. Please PM me with further questions you may have. |
10-26-2015, 07:37 PM | #17 |
3776
Rep 54,160
Drives: F80 M3
