M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      12-11-2012, 08:05 PM   #1
bowen600
Drives: 2013 silverstone M5
5W-30 engine oil
Manual recommends 10W-30 for new F10. Can a can here and there of 5W-30 hurt anything.
      12-11-2012, 08:31 PM   #2
Used2be
Perennial PFC
Used2be's Avatar
335
Drives: F90 M5 DG/Aragon
The PDF online manual specifies 0W-30 or 0W-40, with alternative weight of 5W-30 or 5W-40. Be sure the oil meets the ACEA A3/B4 or API SK/CF specification. Just look for the right spec on the can and the weight difference shouldn't matter. I haven't had a turbo motor before, and perhaps the oil spec is more important in this application.
      12-11-2012, 08:36 PM   #3
deathray
57
Drives: F85 X5M, iX 50, Range Rover
The manual recommends either 0w-30, 0w-40, 5w-30 or 5w-40.
As far as I know, unless youre dealing with cold starts, the higher number is the only one that is really relevant. I use 5w-30 in both my F10 M5 and my X5M without any issues (and I am concerned about cold starts because it gets pretty frigid where I am).
      12-11-2012, 08:45 PM   #4
AGS
AGS's Avatar
496
Drives: 2022 M5 Competition
The dealer put 5W-30 in for my 1,200 mile break-in service.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      12-11-2012, 09:00 PM   #5
bobblehead
bobblehead's Avatar
256
Drives: warp speed
10w30 . I don't see that listed anywhere.
Like the others have suggested. If you go any dealers, they will put 5w30 into your M5.
      12-11-2012, 09:07 PM   #6
Ak3249
Ak3249's Avatar
13
Drives: BMW F12 M6 Cab
My dealer used 5w-30 too.
      12-12-2012, 03:57 PM   #7
bowen600
bowen600
Can one use 10W30 in an F10 M5
      02-01-2013, 10:44 PM   #8
ufgtrs2007
dentite
ufgtrs2007's Avatar
339
Drives: 718 GT4, M2C, JLU392, e92 M3
2013 BMW M3  [0.00]
2013 BMW M5  [0.00]
What's the oil part number that they placed?
      02-09-2013, 02:54 PM   #9
ImpetuousRacer
ImpetuousRacer's Avatar
66
Drives: 2017 Tesla Model X P100D
2013 BMW M5  [0.00]
My dealer put in 07-51-0-017-954 5W-30
I picked up some Castrol Edge Professional OE 5W-30 for top off, it's LL-04. Should I have picked up a different kind. BMW Performance 5W-30 LL-01?
Want to make sure Im getting the right stuff. Thanks!
      02-11-2013, 08:22 AM   #10
boots
Curve Thrasher
boots's Avatar
620
Drives: 2013 Bmw m5..White/Blk.
I use the same castrol edge. You wont have a problem The manual has that one on the approved list.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run
      02-13-2013, 07:39 AM   #11
dr.skp.ortho
dr.skp.ortho's Avatar
Australia
15
Drives: 991 911 Carrera S, F06 M6 GC
I thought the recommended standard was LL01?
Porsche 991 911 Carrera S
BMW F06 M6 Gran Coupe
BMW F15 X5 5.0 Xdrive M Sport.
Mercedes C250
      02-18-2013, 08:20 PM   #12
anchimo
Drives: M5, white, orange/red
The following is the only recommended and approved synthetic oil for BMW M (Motorsport) vehicles in the US market with gasoline engines, at the present time.
BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles equipped with S54, S62, S65 or S85 engines:
Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil
Castrol Formula RS SAE 10W-60 Synthetic Engine Oil (BMW part number 07 51 0 009 420)
If Castrol High Performance Synthetic Oil is not available and you need to add oil between oil changes, only use synthetic oils with the following specifications for M vehicles:
Viscosity - preferred SAE 10W-60
Alternative - SAE 10W-40, SAE 5W-50 or SAE 10W-50
Use only oils with an API rating of SJ/CF, SK/CF or higher.
      02-18-2013, 09:02 PM   #13
Used2be
Perennial PFC
Used2be's Avatar
335
That is an unfortunate first post. Do some more research, you are wrong.
      02-18-2013, 11:27 PM   #14
Netwon
Netwon's Avatar
Drives: '12 BMW M5 Alpine White
2012 BMW M5  [0.00]
Obsolete technical document you are referring to... 2012+ M5/M6 engine code is S65tu. What is the date of issue on the pdf?
BMW could learn from other manufactures that rhyme with "iota" (don't flame me too bad) when issuing such documents! Put an expiry date or clearly state the date(s) of production it applies to. Not just an open ended document good for ever and ever. When I bought my M5 and first had to add oil I was confused as the manual and what was in my trunk from the dealer were different (TWS 10w60). I wanted to confirm this and I had to call 4 different BMW dealers before one in Canada (Edmonton x2, Calgary x2 and finally a Vancouver dealer (took 30 minutes to ask Master Technician) that told me BMW Performance 5W30 was a correct oil (there are 3 other weights we can use).
My point is that the first three dealers refereed to the above document as gospel... dangerous! I guess the saying is correct owners often know more then the dealers selling the car.
      02-19-2013, 08:05 AM   #15
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
my dealer actually thanked me for telling them 10W-60 was wrong (thanks to this forum).
when you switch to one of the correct oil specs, you'll feel the difference.
      02-20-2013, 01:41 AM   #16
anchimo
my dealer put the 5w30 for 1200 service
      02-20-2013, 05:21 AM   #17
nybimmerfan
nybimmerfan's Avatar
35
Drives: 6-Spd Manual MCB M5
Always refer to the manual that comes with the model year of the car. The 2013 M5 Sedan owner's manual states on page 177 to use SAE0W-30 or SAE0W-40 or alternatively,
SAE5W-30 or SAE5W-40 with specifications ACEA A3/B4, API SK/CF or superior grade specification. Page 178 states "BMW recommends Castrol".
      02-20-2013, 05:25 AM   #18
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
The BMW dealer here in my location actually uses Shell, due to sponsorship contract. The only Castrol they use is 10W-60 for other M cars (not F10 M5).
      02-22-2013, 03:43 AM   #19
py0413
py0413's Avatar
108
Drives: Slow
when I signed the paperworks, one of the pages mentioned about engine oil being used at dealership is 5w-30. That's a good because getting them will be much easier and probably cheaper than 10w60 used in the M3 I had before. (dealers charge $23/1L for the 10w60)
Must stop eating..............
      03-31-2013, 06:39 PM   #20
maem2501
maem2501's Avatar
Drives: 2013 Alpine White M5
Smile
Operating Fluids approve by BMW Engines
2013 F10 Alpine White
2013 LS460L
2011 Audi Q7
      04-01-2013, 11:37 PM   #21
stealth.pilot
Knight Commander
stealth.pilot's Avatar
554
Drives: 2014 911 Turbo S
Thanks for posting this. What do you think of running German Castrol 0W-30 in Miami?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      04-02-2013, 10:34 AM   #22
Un Gato Malodoro
Un Gato Malodoro's Avatar
25
Drives: 2013 Azurite Black F10 M5
Has anyone ever used AMSOIL? I've read good reviews but would be interested in thoughts on their product.
Search this Thread:
Advanced Search
m5post
