What is active steering?
08-14-2007, 01:20 AM | #2 |
379
Rep 4,320
Drives: '07 Z4 M Coupe
it's when you.....
08-14-2007, 01:23 AM | #3 |
95
Rep 2,573
Drives: AW DCT M3
I have it and I love it... Read below
"Active Steering." Unlike regular power steering, which has either a fixed or narrowly variable steering ratio, or full steer-by-wire, where the only connection between the steering wheel and the road wheels are electrical wires, Active Steering connects the steering wheel and road wheels through a planetary gearbox. An electric motor--acting through a self-inhibiting planetary gear transmission--adds or subtracts steering angle based on information from a rotational sensor in the steering wheel, vehicle speed, and information from the vehicles stability control system. Steering force is determined by BMW's Servotronic power steering system. At low speeds, the motor adds an appropriate amount of wheel lock. Parking, for example, the ratio is such that just two turns are needed to go lock-to-lock. Around town, the steering ratio is increased, though the system is tuned to be much more direct than a conventional power steering unit. The idea is to make the car feel more agile and nimble, and cut driver fatigue by reducing the input from the driver through the steering wheel. At high speeds, Active Steering makes the steering much more indirect so small movements won't change the vehicle's path. BMW claims Active Steering increases the dynamic envelope by quelling incipient oversteer in maneuvers like high-speed lane changes, reducing the need for steering input when braking on uneven surfaces, or adjusting steering angle to changing levels of grip. As a result, Dynamic Stability Control is called upon less often, and can be initiated less aggressively to keep the car heading in the right direction
08-14-2007, 01:25 AM | #5 |
95
Rep 2,573
Drives: AW DCT M3
I didnt either. I have it too. I just looked it up though.
08-14-2007, 01:28 AM | #6 |
Powered By 36DD
339
Rep 7,369
I want power steering for my 330i..........
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
08-14-2007, 01:34 AM | #7 |
1149
Rep 12,445
Wasn't there a thread a ways back debating the pro's and con's between Active and non-Active steering?
I didn't get the option 'cause it was mighty expensive for being something that isn't exactly a necessary option. Hope I didn't make a mistake.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
08-14-2007, 04:20 AM | #8 | |
478
Rep 3,044
Drives: 2011 Dakar Yellow M3, 2018 M5
- esquire
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] |
08-14-2007, 04:39 AM | #9 |
1149
Rep 12,445
I'm already set...check the sig. My fear was a loss of steering feel. What made you choose it? I've test driven 3 335i's (2 e90's, 1 e92), and each did without it.
08-14-2007, 06:37 AM | #10 |
Rep 112
08-14-2007, 07:42 AM | #11 |
149
Rep 2,278
I'm am very fond of the active steering on my 335. I live in a dense urban area and do a lot of quick turning in lots etc. My car really has the go-kart steering feel.
I read the article in this month's Rondel on how it works. I simply could not really grasp the mechanism. Probably would be able to if I was an engineer. Eleven years of college down the drain!
2015 f80 M3, 2016 GT3
08-14-2007, 07:47 AM | #12 |
Rep 49
+1
2004 545i Sapphire Black/Black 6-spd MT, Sport, AS, CWP, Nav, Logic 7, Bluetooth, iPod. Placed Order 6/04. took delivery 8/04.
On Order- 2008 335i Coupe 6-spd MT, Montego Blue, Sport, Premium, CWP, Nav, PDC, AS, Rear Shade, HD, Sat, Ipod, L7, CA, PCD |
08-14-2007, 08:27 AM | #13 |
95
Rep 2,573
Drives: AW DCT M3
08-14-2007, 08:39 AM | #14 |
25
Rep 341
I say- if its $.. prbly cool gadget, but if it's $$$$$.. it must be good and we'll prbly not know if it works or not.
Just like these fuel efficient Dodge V8's where they shut off 4 cylinders while cruisin'. Why didn't they just give us a button to shut it off, rather than automatically shut off. HOw do we even know if it really shut off 4 cylinders or not.
Broken promises don't upset me. I just think, why did they believe me? |
08-14-2007, 08:42 AM | #15 |
56
Rep 340
It's the perfect way to screw up a BMW. Just my opinion of course. Some people love it. I think they all have beards.
E90 330i Monaco Blue, Black Leather, Aluminum Trim, Six Speed, Aluminum Pedals, M-Shifter, Sport Package, Premium Package, Winter Package, Comfort Access, Navigation
Holding a space for Racing Green Lotus Elise |
08-14-2007, 08:44 AM | #16 |
95
Rep 2,573
Drives: AW DCT M3
ha ha ha.... No beard here though
08-14-2007, 10:16 AM | #18 |
18085
Rep 9,381
It a funky steering system that lets you curb the back end of a 5 series on a test drive going around a normal corner that you drive all the time and had no problem with in the non-AS 3 . . . GUILTY as charged. They didn't let me park the 5 when I got back to the lot
08-14-2007, 10:37 AM | #19 |
Rep 106
Drives: E36 318ti, E90 325i
I've recently had the opportunity to drive a regular steer E90 330i against my 325i with active steering back to back - there is no question in my mind that the AS system is worth the money.
The only difference between the two apart from the steering ratios was that the 330's steering felt slightly more weighter at city speeds- which is why some people might mistakenly believe this for reduced "feel" - but other than that, the road surface, the steering feedback through corners, and the vibration of the engine though the steering wheel was exactly the same.
08-14-2007, 11:11 AM | #20 |
99
Rep 1,828
Drives: 2016 Tesla Model X P90DL
Honestly, AS worked so well on my last test drive (E92 TT) i had a hard time figuring out it was there. It works so seemlessly that you never know it's there, just the fact that you dont take your hands off the steering wheel going into 99% of corners
Feel and weight is almost the same. Well, i ordered this option :rocks: |
08-14-2007, 11:13 AM | #21 |
1573
Rep 4,577
Have it and love it. I probably won't get a BMW without it. This is my second one with it.
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
08-14-2007, 11:23 AM | #22 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
I've never driven a car that has it, but I like being able to turn my wheel very slightly and know exactly where I'm going--regardless of whether I am on Main Street or I65. That's why I was never interested....
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
