E92 - plastic underbody piece ID?
12-02-2012, 08:58 AM | #1 |
Rep 23
I've searched realoem and here on several occasions, and I still can't find an ID or part number on the plastic underbody part that has partially ripped off of my car. I believe it's the one in "step one" of any undercar maintenance of the diff or the transfer case, the one held on by the 8mm bolts, but I just can't find it listed anywhere. Any help would be appreciated, especially with winter just around the corner. Thanks - Pat
12-03-2012, 12:28 PM | #3 |
12
Rep 294
It's probably there, you just need to find it.
For my 07 e90 I had to go to 51 Vehicle Trim -> 51 75 Mounting parts, engine compartment and in there you would find "Underfloor coating" and "Shield,engine compartm./underfloor panel" that has the plastic parts. Not very intuitive that it's under mounting parts but it's there. |
12-03-2012, 06:40 PM | #4 |
Rep 23
Thanks for the encouragement, I finally found it by "drilling down" thru the images, instead of the other way I had tried to find it. I'll try to get it here and installed if I can get one more abnormally warm day.
