M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
Closed Thread
      11-22-2012, 02:42 PM   #1
nugent
nugent's Avatar
65
Drives: f10 m5
argh! v1 hardwire install failed!
i Followed DIY guide exactly: http://www.bimmerfest.com/forums/showthread.php?t=515517
Anyone else have issues or suggestions?
Thanks.
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
      11-22-2012, 03:49 PM   #2
AGS
AGS's Avatar
499
Drives: 2022 M5 Competition
Originally Posted by nugent View Post
i Followed DIY guide exactly: http://www.bimmerfest.com/forums/sho...d.php?t=515517
Thanks.
I used the same instructions and mine works perfectly. Which connectors are you using? On my E60, it would turn off and on if I hit a hard bump because the connector didn't have a snug fit.
What issue are you having?
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      11-22-2012, 06:23 PM   #3
thebishman
531
Drives: ‘24 iX M60
Almost guarantee one of your connections isn't secure.
Bish
      11-22-2012, 09:08 PM   #4
nugent
nugent's Avatar
65
Drives: f10 m5
I'm using hardwire connectors that came with the v1. plug everything in, turn car fully on and I get no power in unit. how can I test connectors? I'm thinking goto RadioShack tomorrow and get volt meter to make sure the green brown wire has the right voltage. what external 12 volt source can I use to test connectors?
      11-22-2012, 09:14 PM   #5
nugent
nugent's Avatar
65
Drives: f10 m5
I figure I'll also get new wiring harness connector too.
      11-23-2012, 08:11 AM   #6
AGS
AGS's Avatar
499
Bish
Assuming you tapped into the correct wires, as Bish said the issue is a bad connection. The blue tap connector that comes with the V1 is for 14 - 18 guage wire. The OP in the installation guide used red tap connectors that are for 16 - 22 gauge wire. The wires you tap into in the overhead console seem to be either 18 or 20 gauge. To utilize the blue tap connector you need to take extra care that you get through the wire casing so the connector can make good contact. I also used blue tap connectors and to assure a tight connection I did two things:
1. Use needle nose pliers to squeeze the metal "U" the tap connector that the wire in the overhead console will slide into. Making it a little bit narrower will help the connector cut through the wire casing.
2. Once you snap the connector shut, gently slide it back and forth on the wire.
Try these two things and see if you can get it to work.
      11-23-2012, 11:09 AM   #7
Tigumz
22
Drives: 1M-VO; Z8(03)-Blk
2003 BMW Z8  [0.00]
2011 Bmw 1M  [0.00]
Echo the above comments and especially check your ground connection. In my E39 and E60 hardwires, I grounded to one of the screws on the sunroof motor.
Seems the green-brown wire in this area has consistently been the ticket for power over the model years, IIRC.....
I need to do this mod soon to get rid of dangling wires...
Garage: 2020 Porsche Tycan 4S
2018 Porsche GT3 Touring, 58 356 Coupe
2014 McLaren 12C Spider
2004 Ferrari 360CS, 07 Lotus Exige S
Former M cars: Euro E30 M3, 01 E39 M5, 08 E60 M5, F10 M5, 18 M2Comp
      11-23-2012, 11:26 AM   #8
AGS
AGS's Avatar
499
I did the same on my E39 and E60 M5s, however I couldn't get any of the sunroof screws to work when I hard wired into the F10. Had to use the wire as described in he step-by-step instructions quoted above.
      11-23-2012, 09:33 PM   #9
nugent
nugent's Avatar
65
Drives: f10 m5
praise the gods! I finally got it to work! thanks for the helpful suggestions. I did need a narrower connector and grounding is needed after all.
      11-24-2012, 06:28 AM   #10
AGS
AGS's Avatar
499
Great, now get out there and drive!!!!
Closed Thread
Search this Thread:
Advanced Search
m5post
