2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: Hamann Style Lip installation
      11-21-2012, 01:34 PM   #1
SirNicholas
SirNicholas's Avatar
26
Drives: f10 535i
Couldn't find a DIY for a HM Style Lip installation on an F10, so decided to make one after asking around for advice.
Tools used:
  • Microfiber towels + Rubbing Alcohol
  • Flathead screwdriver
  • Socket Wrench
  • 3M double sided adhesive
  • 8 bolts, 8 nuts,
  • 16 washers, 8 lock-tight washers
1. The lip's holes should perfectly line up with the existing holes of your M-tech bumper. Remove any existing hardware from the bottom of your bumper.
2. Prep the hardware for the install. You'll need 8 bolts with 8 nuts. 4 go in the corners and 4 go in the middle in my setup.
On the sides, I put the bolts from the inside of the bumper facing down and the nut at the bottom. In the inner 4, the bolts went upwards with the nut being on top.
Four bolts on the sides:
Nut <- Lock-tight washer <- Washer <- HM Lip <- Bumper <- Washer <- Bolt
Four bolts on the middle:
Bolt <- Washer <- HM Lip <- Bumper <- Washer <- Lock-tight Washer <- Nut
3. Clean the surface of the lip and the bottom of your bumper with rubbing alcohol and microfiber. Let it dry. Then place the 3M two sided tape on the front and sides of the bumper and peel off the red film. If you make a mistake and need to take it off, roll off the tape (don't pull on it).
4. You'll need two people to make the install easy. Once the tape is peeled off, have a friend hold one side (without pressing it against the bumper so the tape doesn't stick) while you put on the other side. Since the side bolts are hanging from the top, you need to align the holes and let the two bolts come through, then put on the washer, lock-tight washer and finally the nut. Use your finger to press down on the bolt from the top as you initially tighten the nut with your other hand. Repeat this for the other side. Once all four bolts are secured, use the socket wrench to tighten it. I was able to get all four very tight. The lock-tight should prevent them from getting loose easily.
5. For the inside four holes, you need a bolt with a washer to go from the bottom through the holes of the lip and the bumper. Then from the top, reach underneath the car and put a washer and lock-tight washer onto the bolt, then a nut. Secure all four bolts and tighten with your fingers. Then finally put the socket wrench on the nut (there is enough room above the bottom of the bumper to stick on the socket wrench and hold it tight so the nut doesn't turn as you tighten the bolt from the bottom with a screwdriver. Alternatively you can hold the bolt in place with a screwdriver and tighten the nut with the socket wrench. Both worked for me.
7. Finally, clean up and post pictures!
Big thanks to my buddy Jack (@jyerabutar from e46fanatics) who helped with the install.
      08-01-2013, 09:54 PM   #2
sanyomats
24
Drives: 535, 328
Awesome! Any additional pics?
      08-02-2013, 01:12 AM   #3
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
great write up
I didn't have the nerve when I bought mine so I had them install it for me
      08-02-2013, 03:07 PM   #4
sanyomats
24
Drives: 535, 328
^ any pics to share?
      08-02-2013, 03:13 PM   #5
MELLOWYELLOW06
331
      08-06-2013, 06:44 AM   #6
M5007
M5007's Avatar
71
Drives: 2014 M5 Competition Package
Nice write up. Almost exactly how uninstalled the CF lip on the E92 M3. Now I am just trying to decide on which lip to install. Debating between the BMW Performance CF front spoiler and this one.
      08-07-2013, 11:11 PM   #7
sanyomats
24
Drives: 535, 328
Originally Posted by MELLOWYELLOW06
Awesome! What are you lowered on??
      09-18-2013, 12:00 PM   #8
Mr.skytech
52
Drives: Point A to point B in style
What is the OEM part number for this upgrade. It looks awesome.
      09-21-2013, 05:30 PM   #9
ausdude
ausdude's Avatar
Drives: 2013 BMW 550i M Sport
I have a question about the 3M Tape. The 3M double sided tape with the red backing comes in 3 different strengths... 5lb (Clear), 10lb (Gray), and 20lb(Dark Gray/Blackish). It's the gray 10lb one, correct?
      10-01-2013, 01:55 AM   #10
gre8tw8LL
Drives: 2012 F10 535i
Where and how much did everyone end up purchasing their Hm Style front lip?
thanks.
2012 535i Alpine White | Oyster Black Dakota Interior | Hamann Front Lip | LiteSpeed Catback Exhaust | M5 Diffuser| Painted Calipers & Reflectors | Black Gloss Grill | LED interior lights | Piaa Plasma Yellow Foglights | Born on 1/30/12
      10-01-2013, 09:33 AM   #11
MELLOWYELLOW06
331
thanks
they are h&r
love the ride
      10-07-2013, 01:22 PM   #12
SirNicholas
26
Drives: f10 535i
I would get the best one. I forgot which one I used, but the tape didn't stick at all. The lip is currently only attached through the hardware on my car (locktite really holds it in place ).
Here is another where you can see the fitment.
      01-27-2014, 09:41 AM   #13
Alan328xi
Drives: BMW 328xi 2015
for how much and where did you get it?
      01-27-2014, 10:36 AM   #14
gre8tw8LL
I got my lip from this seller. fitment was on point. Installed it 2 days ago.
http://www.ebay.com/itm/BMW-F10-HM-S...10f5df&vxp=mtr
      01-27-2014, 10:37 AM   #15
gre8tw8LL
Great Write up, took your suggetions and installtion was great.
      02-15-2014, 01:38 AM   #16
EZDozzit
Civilian
EZDozzit's Avatar
14
Drives: 2014 550i M Sport
SirNicholas, so you didn't use the other pre-drilled holes on the lip, which are intended for self-tapping screws. You only used the ones on the rear edge of the lip, which perfectly line up with the holes on the bumper underside, correct? So if the 3M tape isn't doing anything, basically your lip is being held by just the screws you placed on the rear edge as per the pics.
Warning, I'm prone to sudden attacks of enthusiasm.
__________________________________________
2014 BMW 550i M Sport - Jet Black
2014 BMW X6 35i - Black Sapphire
2011 BMW X5 50i - Titanium Silver (traded)
      02-15-2014, 07:26 PM   #17
jdmfrogg
27
Drives: 2011 535
Mine only uses the 4 oem screws in the rear center and then 2 bolts, washers and nuts on the outside edges, no self tapping or non oem holes for my setup. This holds the lip fine on its own but there is a gap on the front edge so I use 3m molding tape to keep things tight.
There seems to be a few different reps sold - some with or without additional pre drilled mounting holes for self tapping screws. The one I got does have these holes for the very front edge of the lip but since I don't want self tapped holes in my bumper (for when I decide to change lips) I currently use double sided tape. The reps have different fits due to different molds used so you'll have to experiment on how much tape to use, where to place the tape and what kind (3m molding tape available at retail stores or one of 30 different 3m VHB models available online only).
      02-15-2014, 10:52 PM   #18
EZDozzit
Civilian
EZDozzit's Avatar
14
So with the 3M tape, you were able to address the gap issue without using screws and it's holding up pretty well? Thanks for sharing. Good to know.
      02-16-2014, 10:45 AM   #19
jdmfrogg
27
Drives: 2011 535
Sorta...
I currently have 3m molding tape (from Autozone) placed only on the center section towards the front of the lip but not so far up that you can see the grey 3m tape. The issue my rep has is that the gap from the lip and bumper needs 2 layers of 3m tape stacked to make strong contact with the lip surface and bumper surface. After a month of monitoring it, I'm seeing that the doubled up take is starting to separate. The 3m molding tape and the adhesive is designed for a very specific surface energy - in this case glossy or very smooth surfaces like paint. Since I'm trying to stick 2 pieces of tape together, it eventually will fail. My next plan is to use a small shim (1inch x 6 inch long x 1/8inch thick plexiglass strip) to adhere the 3m molding tape to, then use that sandwiched between the lip + bumper... in theory this should work and solve the problem. If this does not work, I was going to buy 3m VHB... that will work FOR SURE... google it or check it out on Youtube.
      02-16-2014, 02:00 PM   #20
PanaricanDad
PanaricanDad's Avatar
Drives: 2011 550i M Sport
Been following this thread and admire everyone's efforts to install this spoiler so there are no gaps. I picked up the spoiler from the ebay seller's warehouse last week in SoCal. Went to Home Depot and bought the suggested mounting hardware and 3M tape. The holes line up perfectly and the quality looks good. However, I found the install to be a bit challenging given the protective stuff tucked under and attached to the bumper. After a couple of beers I tapped out on this particular DIY mod project and will head to my mod shop guy where they can put it on a rack and install it properly.
2011 BMW 550i M Sport
2002 MB CLK 55 AMG Cabriolet (donated to charity)
2002 Honda S2000 (<70k miles)
1993 Acura NSX (<95k miles)
2 American-made SUVs for shuttling twins to school
      03-01-2014, 02:24 PM   #21
PanaricanDad
Finished product. They removed the front bumper and used the suggested hardware. Looks good and fits well.
      03-01-2014, 11:30 PM   #22
EZDozzit
Civilian
EZDozzit's Avatar
14
With or without 3M tape?
5post
