Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Viewing measured tire pressure
      11-19-2012, 03:19 PM   #1
alexwhittemore
111
Drives: 2009 Crimson 328i
So I'm PRETTY SURE my car (e90 LCI 328i) has active tire pressure monitoring. In the BC menus, I can set the pressure units to either PSI or kPa, suggesting that somewhere, actual pressure values will be displayed. The question is, where? Is there anywhere to actively look at the tire pressures? Does the measured pressure pop up if the TPMS flags it as low?
      11-19-2012, 06:54 PM   #2
Tom K.
Tom K.'s Avatar
124
Drives: '07 328iT, '13 Boxster
Unlike some other manufacturers, BMW does not chose to display actual individual tire pressures. I have no idea why there is a iDrive setting for pressure units - it's not available on non iDrive equipped one series models - but it is apparently a dummy setting for the US. So if you discover some way of getting a psi display, let us know!
Depending on the year and software reflash, the TPMS error message will indicate which tire is low. It generally comes on when the pressure has dropped about 25% below the baseline setting.
Tom
      11-19-2012, 07:00 PM   #3
alexwhittemore
111
Hmm. Sounds like I'll have to break out the compressor/gauge/can cable and fiddle+pray.
EDIT: So there's this, in KOMBI
K4116_C_TEMPERATUR_1
wert_02
K4116_C_TEMPERATUR_2
wert_02
K4116_C_TEMPERATUR_3
wert_02
K4116_C_TEMPERATUR_4
wert_02
K4116_D_TEMPERATUR
wert_02
K4119_C_DRUCK_1
wert_03
K4119_C_DRUCK_2
wert_03
K4119_C_DRUCK_3
wert_03
K4119_C_DRUCK_4
wert_03
K4119_D_DRUCK
wert_03
Druck=pressure, and temperatur is interesting since, in some iDrive models, tire temperature is displayed as well. Of course, I have no idea what the wert_03 setting corresponds to.
Hmm. There's also
AUSWERTUNG_B_DRUCK
in CAS, default nicht_aktiv. Setting active doesn't seem to change anything.
      11-21-2012, 01:51 AM   #4
alexwhittemore
111
Anybody else have any input?
      11-23-2012, 07:01 AM   #5
rorkor
rorkor's Avatar
Drives: '11 E90 N52 6MT
2010 E70 X5 35d  [10.00]
2011 E90 328i  [10.00]
I have been told that the e90 M3 was supposed to have active tire monitoring but was not implemented. This may be junk coding left behind because it was cheaper than going in to remove it. I am going to look into it though because I would love the feature for track use.
      11-23-2012, 09:24 AM   #6
SubzeroVR4
SubzeroVR4's Avatar
70
Drives: F80 M3/F85 X5M
I would like to know as well. I have this feature on my FX35 and it's nice to be able to see the cold and hot pressures real time.
'16 BMW M3
'16 BMW X5M
'23 X3 M40i (On Order)
'21 Civic Type R
      11-23-2012, 09:54 AM   #7
NiVeDh
NiVeDh's Avatar
422
Drives: '08 E90 335i, '99 E36 M3
It's available on the F-series (coding).
