Charging the battery
11-19-2012, 06:57 AM | #1 |
Rep 313
Hi,
I've used the search to look at what people have said about replacing and OEM vs aftermarket etc etc but I just wanted some clarity on trying to charge an existing one that has thrown up the battery icon on the dash (before forking out for a new one) I've never had a car with a battery in the boot before, let alone one with apparent charging points under the bonnet. Is it just as simple as connecting my charger to said points and letting it work it's magic? I've seen a lot of people using CTEK chargers but will my Halfords one suffice? (some have suggested 'cheaper' chargers may do some harm) Thanks as always |
11-19-2012, 09:46 AM | #2 |
Dieseasal
204
Rep 6,881
Yes just connect to the bonnet terminals nothing special needed..
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
11-19-2012, 11:37 AM | #3 |
888
Rep 9,097
You can also charged it from 'under the hood' terminals.
11-21-2012, 02:02 AM | #6 |
Rep 3
I have a CTEK 3600 which I use for my other car via cig lighter socket....
I was wondering if it was safe to use this charger in a new BMW 3 seriers E93 cig socket? Many thanks |
11-21-2012, 02:09 AM | #7 | |
1545
Rep 8,972
OP - the battery wanring light just means the charge is low, doesn't necessarily mean the battery is knackered. Do yo do a lot of short runs?
If so take it for a good long run (at least 1 hour, main roads) and see if that helps. If you do need to change the battery, there's no such thing as an 'OE' battery, just any quality one will do. But yes, just connect your positive charger clip (any old crappy charger will do) onto the red terminal under the bonnet, it is just an extension of the main positive connection to the battery. Find a good bit of clean metal (engine mounts?) to put your negative charger clip. Their is a small ground stud on the inner wing near the positive terminal, but it is quite small, better to grab a big chunk of engine. Quote:
Bit of an odd way to do it, ok for conditioning though, but not charging from flat as the ciggy lighter fuse would blow!! Last edited by doughboy; 11-21-2012 at 02:33 AM.. |
11-21-2012, 02:47 AM | #8 |
Rep 313
Cheers Doughboy, yes it does suffer from short trip syndrome, when it came on I took it out for a decent blast for about 45 mins and didn't see the next time I started it up but it still sounds a bit laboured on crank (not to be confused with long crank, more slow)
Think I will still top it up given it will be used even less in the Winter - though it might get lucky with a 6hr round trip to Birmingham next week |
11-21-2012, 03:00 AM | #9 | |
Rep 3
I just want to condition battery some days.... Whats the easiest way to do this? Will my CTEK 3600 be okay? Many thanks for your reply... |
11-21-2012, 11:30 AM | #10 | |
136
Rep 5,050
11-21-2012, 12:29 PM | #11 |
888
Rep 9,097
OP
Have you checked the actual volts at the battery when car is off? You can use multi-meter to do that.
