BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > 1st time @ track, disappointing results
      11-18-2012, 07:02 AM   #1
spool twice
Rainbow Racer
spool twice's Avatar
1008
Drives: BMW M4cs
2019 M4cs  [0.00]
I couldn't get traction I was getting 2.4-2.5 60ft's all day
r/t .076
60' 2.359
1/8 9.074 @ 90.30 mph
1/4mile 13.487 @ 111.94 mph
JB4 G5, DCI, methanol, E85/93 octane, 6MT. My car wouldn't boost past 16.5psi for some reason(?) even though I have my additive set to 7 (19.5psi), kept getting a plausible fuel pump code, and kept missing 2nd gear. Only ran 4 times because it was an epic fail and quit
I had my tire pressure set at 38psi on PS2 RFT. Definitely will be going back, I need more practice on my launching, and to figure out my fuel pump code.
3,500rpm w/ a quick clutch slip @ part throttle. 6,000rpm shift points, I didn't get a chance to deviate from those methods. Nonetheless, a 112mph trap speed isn't terrible, the ET of 13.5 is. I ran with one push of the T/C button (DTC light)
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ]
Current Car: F82 M4cs | TT-RS | On Order: i4 M50
      11-18-2012, 10:43 PM   #2
The Ghost
Reborn
The Ghost's Avatar
84
Drives: 335i
You need to hold the DTC so it is all the way off.
      11-19-2012, 03:44 PM   #3
See5
BMW Fan
See5's Avatar
449
Drives: Nothing
Yeah, I'd go all nannies off first. These cars aren't going to get away from you in my experience. I've driven a few cars that would love you send you into a wall if given the chance.
Second I'd lower the tire pressures some. On street tires you don't want to go really low but but 38 seems pretty high to me. I'm new to BMW's though, they might react differently. I used to run about 28-30psi at the drag strip in my C5 when on streets tires.
After that its all clutch work and launch. Not easy in the least bit.
      11-23-2012, 07:22 PM   #4
spool twice
Rainbow Racer
1008
Drives: BMW M4cs
2019 M4cs  [0.00]
went back again to a turkey trot event, I was only able to get 3 runs this evening within a 1 1/2hr time frame so I'll have to go back another time.
All DTC/DSC nannies off
Launched @ 2,000rpm and eased into the throttle in 1st gear, still spun
Tire pressure 32psi rear on PS2 RFT
Limited 1st gear to 10psi
short shifted 1-2 @ 6,000rpm because of traction issue's
shifted at 6,300rpm 2-3 and 3-4
JB4 ISO, E50 blend w/ 93 octane, DCI, 80/20 water/meth mixture 50 additive, peaked 17.5psi
60' 2.002
330 5.971
1/8 8.774 @ 91.30
1000 11.249
1/4 12.627 @ 113.98
All in all, not bad for my 2nd try.
-Loe P.-
      11-24-2012, 07:10 PM   #5
AWil335i
AWil335i's Avatar
12
Drives: 2007 E92 335i
Not bad - I have the same tires as you - but will be getting some Pilot Super Sports before next year!
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
      11-27-2012, 10:51 PM   #6
SneakyDeeky
driver mod in progress
SneakyDeeky's Avatar
225
Drives: with both feet
2015 VW Golf R  [5.50]
2014 Audi SQ5  [10.00]
Nice, OP. Michelin Pilot Super Sports are the best street tire I've found yet.
      11-28-2012, 09:59 PM   #7
The Ghost
Reborn
The Ghost's Avatar
84
Drives: 335i
Nice times! Have you checkled your logs? Since it has got colder, I lowered boost to 15psi and it still pulls great (119mph).
They are like glass now that its gotten colder (40-60F). Spins with 4th gear roll-on even with LSD. I was hoping for them to be stickier.
      11-28-2012, 10:45 PM   #8
SneakyDeeky
225
Talking
That's why I live in SoCal... low of 58 today in late November.
      12-08-2012, 06:16 AM   #9
spool twice
Rainbow Racer
1008
Drives: BMW M4cs
2019 M4cs  [0.00]
Nice!! 119mph? what mods?
My fuel trims are pretty elevated since it's been cooler. When I ran above, it was about 70F. When I do logs in 90+F, my fuel trims hover close to 0 with a 50/50 E85/93 + methanol.
-Loe P.-
