Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Front seat squeaking driving me mad!
      11-02-2012, 09:14 AM   #1
BaseM3
BaseM3's Avatar
42
Drives: 2011 Space Grey M3
My drivers sports seat is squeaking bad over every bump in the road. I've searched the forums and siliconed the suggested places but it doesn't help. When I raise or lower the seat the squeak stops for about a minute.
Does anyone have any other suggestions. I'm ready to pull the seat out and grease all the contact points. It sounds like is a spring or coil underneith the seat leather.
Are there any precautions to look for when I remove the seat, airbag, seat belt ballistics, ect.
Any special procedures to remove the seat besides unbolting from the floor rails and disconnecting the electrical Leeds?
Thanks for any help.
11 Space Grey, M-DCT Base M3
      11-02-2012, 09:43 AM   #2
Bagelfast
Bagelfast's Avatar
125
Drives: BMW
Yea my car is a 2010 with 27K and my driver seat, just all of a sudden started squeaking. Its annoying as hell. looking forward to a solution.
      11-02-2012, 10:01 AM   #3
zamboni
I want to drive a Zamboni
zamboni's Avatar
1131
Drives: 13 E93 M3 18 F80 M3 16 K71
16 K71 F800GT  [10.00]
2018 F80 M3  [10.00]
2013 BMW E93 M3  [10.00]
My E82 started havin the same problem.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue
13 E93 M3 Melbourne Red
2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3
My next vehicle would be a Zamboni
      11-02-2012, 10:57 AM   #4
Bamaben
Bamaben's Avatar
183
Drives: 07 335i blk/blk/alum 6MT
My squeak was actually the rubber around the seatbelt fastener rubbing against the leather seat. Fixed it by putting 3m Velcro tape around the rubber on fastener. Just try grabbing the fastener when you hear it next and see if it stops.
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey
mods: blackout grill, finishing rods, badges, Blacklines.
      11-02-2012, 03:31 PM   #5
BaseM3
BaseM3's Avatar
42
I have the felt on the side of the seat belt fasteners, doesn't help. Are you referring to the thick wire part below the fasteners?
      11-02-2012, 08:50 PM   #6
Bamaben
Bamaben's Avatar
183
Yes, dealer put the felt on the fastener and it still squeaked so I wrapped it around the stalk and it stopped
      11-03-2012, 02:09 AM   #7
mwalters
Drives: 3 Series Coupe 07 320d
Squeaky e92 leather seat...
I too have this problem, and it's definitely NOT leather, it is coming from the internals on the right hand side, if I literally spray it til it's dropping wet with WD40 or similar, it goes away for about 30mins!!! It's something to do with the mechanisms.
I would love to be able to get into the damn thing and literally cover it all with a proper grease to fix it for good, rather than the often smelly and short lived results I get from using WD40.
I might add that it only seems to creak when setting off from standing starts etc, and if I lean forward to take pressure off the back rest then it doesn't squeak at all!
Anyone else with similar symptoms?
On my 2nd BMW now, and it'll soon be my last given the quality of the thing. My mother in laws Peugeot is smoother, quieter, and feels more solid than my 2007 E92 320d, and I'm not even joking!
      11-03-2012, 09:51 AM   #8
Yvette
761
Drives: M
when you disconnect
airbag lights will pop up
it won't be cleared even you connect it back, i aldo had squeaking sound but it went away after i remove thr seat and put it back but i still have those lights lol
      11-03-2012, 01:01 PM   #9
BaseM3
BaseM3's Avatar
42
Originally Posted by e90sexion View Post
when you disconnect
That's what I was worried about. I have a BT tool, can I reset the airbag light with it?
It does sound like the mechanism or a spring underneath and not the leather making the noise. I stuffed a rag between the seat belt stalk and the seat and nothing changed.
I found the BT tool question it appears I can reset the light with it.
      11-10-2012, 11:22 PM   #10
ENZOCOREA
Drives: 2007 335i Coupe
i have this problem too, apparently we are not alone
      11-11-2012, 08:19 AM   #11
Yvette
761
Drives: M
when you disconnect
the lights were cleared actually
i disabled light when i had recaro and now i have stock seat, i enabled them back dafault, lights were gone
      11-28-2012, 03:32 PM   #12
BaseM3
BaseM3's Avatar
42
I fixed the squeak on the seat!
Took out the 4 mounting bolts and tilted the seat back to get underneath. I applied a thin film of white lithium grease on all the mechanical pivot points and adjusting mechanisms I could see.
I then sprayed silicone lube with the extension tube on the back attachment points where the seat springs attach to the lower seat frame. I think this was the cause of the squeaking. took about 30mins total. Now theres not a peep from the seat!
