Passenger Seat Headrest Rattle -- How to Fix?
11-02-2012, 07:53 AM | #1 |
Slightly modified...
13
Rep 289
***UPDATE --> Fix can be found on thread #12
Hi Guys, Has anyone else experienced this problem? My passenger headrest rattles every time I hit a bump in the road when driving by myself. Really starting to bother me at this point; any ideas? On stock suspension/sport package on my car if that helps
11-02-2012, 12:34 PM | #3 |
13
Rep 289
Haha, okay -- thanks. Will report back if I find the source of the rattle
11-27-2012, 07:22 AM | #4 |
Rep 24
Same Issue
I have the same issue, the passenger seat or the headrest rattle. It's very annoying. Brand new RFT tires on the car and 45K miles. I had the tires put on at the dealership but maybe I will have them re-balance them to see if that helps.
01-10-2013, 09:32 AM | #5 |
698
Rep 2,012
Drives: '05 M3 6MT
Any updates on this? I found that if I adjust the passenger seat using the power seat controls, it will temporarily relieve the rattle. For me, the rattle isn't when I hit bumps or anything, but usually when I'm driving at a normal driving speed. Gets pretty annoying.
'05 BMW M3 6MT (Weekend car) Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link! |
01-10-2013, 05:48 PM | #6 | |
13
Rep 289
Will let everyone know if I find a solution
01-10-2013, 11:10 PM | #7 |
854
Rep 682
Drives: 2023 G80x M3C
Mine rattles too. And yes, it is effin annoying! What I do to fix it (temporarily) is place the headrest in between the "clicks" -- you know how it clicks at each height level. This works, until I hit a bit bump or someone else messes with it.
Let me know if this works for you, or if you figure anything out. |
01-11-2013, 08:57 AM | #8 | |
13
Rep 289
Okay, I'll have to try this as a fix -- My game plan for the weekend was to attempt removing the headrest and lubing it up with some sort of oil. The headrest comes out, right?! I'd imagine it would...
Anyway, will let you know if the lube treatment helps at all Quote:
01-11-2013, 09:34 AM | #9 |
Rep 562
Could try adding some tape to the metal headrest arms or something - my guess is that if the diameter of the headrest mounts was wider there would be less room for it to rattle?
ZPP / ZSP / Navi
01-11-2013, 09:39 AM | #10 | |
197
Rep 348
01-14-2013, 06:57 AM | #12 |
13
Rep 289
FIXED IT!
As it turned out, my rattle was coming from the metal rod on the right side of the passenger headrest. I applied 1 layer of clear duct tape to the bottom 2/3 of the metal rod, and pushed it back down so the tape was not visible. I have driven roughly 50 miles since I made this change Saturday morning, and haven't had 1 rattle! Myriad is a genius haha Tip: If the tape has more than one layer (overlaps) or has ridges in it when applied, the headrest may not go back down (I learned this the hardway). It causes the tape to bunch up when you put the headrest back down, and you have to remove it/start again
11-30-2018, 01:43 PM | #13 |
Rep 10
I have same rattle noise from passenger headrest on my e93 convertible. On this version, the head rest is electronically controlled. Metal rod is not exposed, so tape-method does not work. anyone know the procedures to remove headrest cover?
