      11-01-2012, 03:38 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
811
Drives: Independent Tuning Specialists
:: ECS Tuning :: The only gauge that doesn't clash with your interior|OE Styling
Need a complete boost gauge kit for a custom application? ECS proudly announces our new universal Boost Gauge Kits. Each kit contains a 42mm illuminated boost gauge, plus pressure transducer, wiring, and hoses.
Just tap into a manifold vacuum source at the engine using the enclosed vacuum tee. Then run a vacuum sampling line into the cabin and connect it to the transducer. Plug in the transducer, and connect the gauge to power with the wiring harness and bullet connectors in the kit.
This versatile package makes it easy to install this bright, accurate gauge, in any car.
Click HERE to order your ECS BMW 45mm Boost Gauge Today!!!!!!!!!
Not for use in Valvetronic Motors
      11-06-2012, 09:52 AM   #2
ECSTuning
ECSTuning's Avatar
811
      11-20-2012, 02:47 PM   #3
ECSTuning
ECSTuning's Avatar
811
There is no better time to buy than NOW!!!!!!!!!!!!!!!!!!!!!!!!
The best boost gauge for your BMW from ECS Tuning is now 15% OFF as part of our 8th Annual Holiday Extravaganza!!!!!!!!
      05-21-2015, 10:59 AM   #4
dbarcliff
Drives: 2008 135i
135i Boost gauge
I have recently purchased this kit for my 1series. I noticed that it does not come with the vent piece to hold the boost gauge in place.. do you have a DIY install to explain how this mounts to the vent? The video/advertising for this is pretty misleading. There arent any instructions with it at all.
      05-21-2015, 11:05 AM   #5
ECSTuning
ECSTuning's Avatar
811
Originally Posted by dbarcliff View Post
I have recently purchased this kit for my 1 series. I noticed that it does not come with the vent piece to hold the boost gauge in place.. do you have a DIY install to explain how this mounts to the vent? The video/advertising for this is pretty misleading. There aren't any instructions with it at all.
The video is showing the kit in the E9X with our E9X gauge pod, it's utilized to simply show the blending of the gauge with the factory lighting. Same goes for any install shots of the gauge. At the current time we do not offer any gauge pods for the E8X. Our gauge is a factory style and color match suggested for custom applications in the 1 series. This is why we state on the site, "For E9X 3 Series models, please see our innovative Vent Pod Boost Gauge Kits for an easy, clean install."
If you'd like feel free to shoot me a PM with your order number and I can get my customer service staff to reach out to set up a return.
-James
      05-21-2015, 11:10 AM   #6
dbarcliff
Drives: 2008 135i
-James
Thanks James for the fast response. Gimme a day to think about it. If I can find a pod I can make work with it i will custom mount it. The gauge is fine and will work fine for what i need. I guess i wasnt paying close enough attention. As in all of the photos i have seen it is mounted into the vent and i assumed it was on a 1 series since it came up on your website for fitting the 1 series and i saw this on 1addicts. not a problem though. I should be able to make it work. If not i will get with you guys and return it. Thanks again!
Search this Thread:
Advanced Search
1addicts
