Heater / ac problem
10-29-2012, 05:02 PM | #1 |
Rep 166
Heater / ac problem
I have a 08 328xi and all of a sudden my fan isn't blowing any air from my heater or ac. Power to all controls just fans aren't working.. Any ideas?
Thanks in advance |
10-31-2012, 09:33 AM | #5 |
36
Rep 409
Pop the hood and look at the air intakes a lot of the time to prevent strain the blower will shut off if theres a blockage. Leaves and such are a common issue.
11-01-2012, 09:06 AM | #6 |
24
Rep 413
Final stage resistor?? They were a MAJOR problem in E46's. Here is a DIY for E9X's http://www.e90post.com/forums/showthread.php?t=500653
07-18-2013, 10:44 AM | #7 |
Rep 143
Drives: 2007 335i sedan a22
subscribed
subscribed
07-18-2013, 12:06 PM | #8 |
164
Rep 401
The blower motor fails commonly in the e9x..the final stage resistor not so much (unlike the e46). My blower motor was making noise for a while (like a squealing hamster cage) due to rusting of the bearing/shaft engagement surfaces. This is usually caused by water that leaks down onto the motor from a faulty cowl assembly not sealing properly. Eventually the motor completely failed where you could hear it spinning, but at a much slower speed than even the slowest setting on the climate control unit and the speed would not change. I replaced the blower motor assembly (which is an extremely easy job by the way) and all is well
12-05-2013, 03:24 AM | #9 |
Rep 3
I had the same problem with my e90 320d. Every time it rains hard, my passenger footwell carpet gets wet. I opened the cover and found my blower motor rusted...... manu328, your blower motor was also rusted?...... Anybodyelse had the same problem?
