Please Help Diagnose - 335i Service Light On.
10-25-2012, 06:30 PM | #1 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
Boffins Needed!
I have a 2007 335i e92 JB4 Map 5 - Shell V Power BMS DCI 65,000 miles Had Turbos warranty replaced 1 month ago. I was on my way home on a relaxed drive. I wanted to pull softly to overtake a lorry whilst going up a small incline. All of a sudden, Engine light came on. I did not even attempt to pull hard to see if i had loss of power. But the engine was immediately running rough. I crawled home for a mile or so under 2k rpm. I tried to read the codes on my JB4 once i was home. But i am unsure if i read it correctly. I have a vid below of what i did. Please direct if that is right and help read the code. There is also a short video of my car idling. I am unsure what the issue may be. I was just about to install my VRSF DPs, i can take the car to BMW if necessary, but i will pull the JB4 and DCI. Need as much info as possible so the stealers dont try to mess me around. Engine Code - Engine Rough Idle - |
10-25-2012, 08:19 PM | #2 |
170
Rep 3,828
Sorry guys but need to bump desperately. I may be forced to crawl the car to the dealer or an Indy... But unsure what the code is or how to read it.
10-25-2012, 08:31 PM | #3 |
17
Rep 522
10-26-2012, 08:49 AM | #7 |
Rep 177
Or just the coil pack and plug in cylinder 4. Fairly rare for packs to go out, let alone all 6, if you replace with OEM then just the 1 should be fine. And this is a relatively general fix for a problem when you aren't sure what exactly caused it, so no sense spending unnecessarily.
