E90 Cold Start Problem
10-23-2012, 04:46 PM | #1 |
Rep 7
I have a 2006 330i Sedan and for the past few weeks when i do a cold start the car wont turn on smoothly. i have attached a sound clip of it. what so i need to fix to get this problem resolved?
Thank you, |
10-23-2012, 10:01 PM | #3 |
51
Rep 605
How many miles do you have, have you replaced the battery?
sounds like its having trouble turning over...Id get the battery tested at autzone for free. might be the starter? I havent heard of faulty fuel pumps in N52's, unless you got some sedimented fuel inside the tank from a bunk gas station. any codes come up? |
10-23-2012, 11:11 PM | #4 | |
34
Rep 280
2009 E82 135i 6MT FBO
10-24-2012, 09:50 PM | #5 | |
Rep 7
no codes at all Thanks |
10-24-2012, 10:02 PM | #6 |
41
Rep 284
Could be the fuel pressure regulator losing pressure overnight and takes a little time to build pressure on initial start up. Could also be a leaking fuel injector/s same scenario, lost pressure and takes some cranking to re build the pressure it's supposed to be holding for quick starts.
I have that thump you have just as it turns over. Dealer checked fuel pump and pressure regulator on mine and found it in spec. They said it could just be the battery not being a BMW battery |
