my car died, while i was driving!!!!
10-21-2012, 01:27 PM | #1 |
50
Rep 527
friday night i went out, i was tired so i went home early, while i was driving, i notice my lights went off and half second after, the entire car is off!!! and i was still driving, luckily i was close to a red light and i was slow.
the entire car was dead, not even the blinkers (flashlights, or hazard lights, i dont really know how they call them) finally the car stop, i tried to turn on the car, bad idea, i put the transmission in Parking, and of course the car got lock, i wasnt available to put on Neutral to can push the car to the side, i was in the middle of the street. i call my insurance, so they can send me a tow truck. ETA 1 hour of waiting. i got off the car, because that night was really foggy and the car was in the middle of the street, while i was waiting the tow truck (more than 1:20 hrs) i started to be cold, so i went to the car to pick up my sweater, when i open the door, i heard the "gong" and i was like "WTF!!". i Tried to turn on the car, and tada!!! the car turned On like nothing happen before!!!!!! i ended up getting home like 5am The last month i noticed that randomly when i turn on the car, i have to set up the clock, like when you disconnect the battery. After that scary episode, i thought could be that the battery is dying, but, if it was the battery the problem, it couldnt turn on again after an hour or so, without giving a jump of anything. so i checked and it looks like is the Alternator, anyone had this problem? can really be the alternator? or something else? i dont wanna go to the Stealership to fix this, any recommended shop around NYC? (e90, 328xi sedan, 2007) |
10-21-2012, 01:31 PM | #2 |
103
Rep 2,783
Might be faulty IBS sensor that is located on one your batter cables (positive?). Do a search on here for it.
10-21-2012, 01:50 PM | #4 |
103
Rep 2,783
Dashboard gives very limited information.
Also, I am not sure if the IBS throws a code if it is faulty using a peake or BT scan tool. If you rely on the dashboard then you may not know how to DIY so take it to an indy shop for diagnosis and repair. By the way, did you change your battery recently? If so, then that is how it broke. The IBS sensor is very fragile.
10-21-2012, 01:56 PM | #5 |
50
Rep 527
i didnt replace the battery (yet)
i talked about the code because after you wrote that i was searching online and everytbody talk about having a code. i want to a indy shop and they measure the battery while the car is off and when is on, and when the car was off, the "tool" says it was in 13 (idk the measure word) and took like 1 min to be in 15 (the optimal number) So basically as soon you turn on the car, should go up to 15 and not taking a minute or so to get there, thats why the mechanic guy said that is the Alternator is having problems. |
10-21-2012, 02:00 PM | #6 | |
103
Rep 2,783
10-21-2012, 02:05 PM | #8 |
103
Rep 2,783
Dealers are even worst! Find a shop that specializes in BMWs. Go to the regional forum on this site and ask around for a recommended indy shop.
10-21-2012, 02:10 PM | #9 |
103
Rep 2,783
Look here http://www.e90post.com/forums/forumdisplay.php?f=48 take a look at the stickies on the top of that page and go from there. Please post an update so if someone has a similar experience they will know (or not know) what to do. Thanks and good luck!
10-23-2012, 09:32 PM | #12 |
68
Rep 961
I have a 2006 325i, and i ve been experiencing it alot lately. I have a manual transmission, and it seems like everytime i slow down while in gear (with the clutch pressed down obviously) the car shuts off. Sometimes when i am in neutral it does the same.
10-29-2012, 08:36 PM | #14 |
Rep 1
Bmw Si B61 08 11
sebanyc I had a similar issue. Car would have complete electrical shut off. There is a service bulletin out for it SIB610811. From my research it turns out there is a faulty connection between battery positive cable and the fuse box. What worked for me is to get both replaced. Check these threads below, they were very helpful. Hope this helps!
http://www.e90post.com/forums/showthread.php?t=566291 http://www.e90post.com/forums/showthread.php?t=549735 |
10-29-2012, 09:42 PM | #15 | |
160
Rep 1,307
Good luck to OP. |
11-04-2012, 04:41 PM | #17 |
Rep 9
I had the same problem, was driving when i saw the red battery light. after that the radio started to turn on and off till it stayed off. then all of the dashboard lights came on....after that all my lights turned off...hazzards headlights fogs etc speedometer stopped working. pulled on the side of the road. called help. they came with a new battery....changed it (was a bleeping nightmare to change). it started like it would normal. drove to my house which was 10min away and the red battery light came back on. is this the alternator?
11-04-2012, 05:54 PM | #18 |
1705
Rep 14,829
This happened to me back in 2010....but I have a 335. Dealer could find nothing, until the car wouldn't even run anymore (after about 6X stalling either on the expressway or in rush hour traffic). They had to replace the DME. The first time they simply replaced the IBS sensor since they had no idea what was going on. No codes, etc.
