BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > are jack pad adapters needed for use with a lift?
      10-09-2012, 09:28 AM   #1
bmodzelewski
20
Drives: 07 335i
are jack pad adapters like this one:
needed for use with a shop lift?
is any adapter needed? or can you just lift the car using the plastic jack pads attached to the bottom of the car?
thanks.
      10-09-2012, 09:31 AM   #2
M3_Dylan
32
Drives: 2008 BMW M3
thanks.
The shop I go to just uses wood blocks.... But thats because I dont really care about the jack pads, otherwise they would use these
KW V3's / AA Stage 2 Supercharger / Catless Mid-pipes / AA Mufflers / Apex Arc-8's / PFC 09's
      10-09-2012, 10:07 AM   #3
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
Without the jack pads, your jack will destroy the jacking point plastic things.
      10-09-2012, 10:15 AM   #4
ndog14
52
Drives: E90 328xi 6MT
OP is talking about a lift. And what type of jack are you using that is detroying the plastic jack points?
      10-09-2012, 10:25 AM   #5
cmyk
resident girl.
cmyk's Avatar
59
Drives: 2008 335i + 2014 X5
2008 BMW 335i  [8.76]
+1. What kind of jack are you using? I have lifted my car countless times using a hydraulic floor jack on the jack points and they are fine.
The last time my car was on a proper lift they used wood blocks I think.
2008 E90 335i // Black Everything // photos
COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i
      10-09-2012, 10:39 AM   #6
Blackhawk36
Blackhawk36's Avatar
30
Drives: 2007 335i 6MT No iDrive
I put mine up on a lift all of time on the plastic jack points and never use jack pad adapters. Never any damage. However, curbs do a number on them ;-). Replacements are on $14 from the dealer.
      10-09-2012, 11:52 AM   #7
rkg
Drives: e90
I use an old baseball glove between the jack and jack point ... never any damage. Of course, always use jack stands once lifted by the hydraulic jack.
      10-09-2012, 12:07 PM   #8
Efthreeoh
General
17314
Drives: The E90 + Z4 Coupe & Z3 R'ster
No. The pads are specifically designed for use with an automotive lift. I have lift in my shop and have lifted my car prob 50 times by now. No damage.
      10-09-2012, 12:19 PM   #9
bmodzelewski
20
Drives: 07 335i
thanks for the info everyone.
      10-09-2012, 04:05 PM   #10
335okc
335okc's Avatar
42
Drives: e90 335
do you have the part number for the Jack point? i bought my car with 1 of them a little crushed. i think the only time it could damage the Jack point is when the lifting surface isn't under the entire Jack point.
      10-09-2012, 09:28 PM   #11
fun2drive
BMWCCA 149159
fun2drive's Avatar
38
Drives: 13 128i Vert/ 14 JGC Diesel
I use a heavy piece of carpet and a 2 X 4 on mine and have zero issues. I also seldom use the actual jack point but right by the jack point. This is a unibody car and if you are close to the area as in right beside it no harm is done jacking or lifting there...
      10-09-2012, 09:32 PM   #12
sibhusky
Drives: 2011 E90 M3
Most shops use a scissor, mid rise or 2 post lift which yes should have a rubber block placed under the jack points
      10-10-2012, 01:02 AM   #13
Bakeme521
Some say...
Bakeme521's Avatar
239
Drives: Fresh
2007 BMW 335i  [8.24]
No it won't, that is what it is made for....
To the OP, no it won't. I have a personal lift and I have put it in the lift easily 20-25 times using the plastic ones with no problem.
I have exhaust and an intake...
      10-10-2012, 09:01 AM   #14
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
Well it sure did on mine. Its not the jack itself that did it, but the jack stand. None have the appropriate shape so they force on the wall of the little plastic adapter and it get crushed.
      10-10-2012, 10:59 AM   #15
335okc
335okc's Avatar
42
Drives: e90 335
jack stand will do that because it doesn't have proper contact with all the side of the jack point.
lift on the other hand will not have this problem.
      10-11-2012, 05:26 AM   #16
Efthreeoh
General
17314
What type and brand lift do you have?
      10-11-2012, 06:52 AM   #17
SpmnE9zero
DENY THE WORLD THAT SURROUNDS YOU
SpmnE9zero's Avatar
505
Drives: JB 33ZERO
2006 330xi  [0.00]
Man all of you guys using items such as "an old baseball glove", "a heavy piece of carpet", I really hope you are utilizing jack stands once the car is up in the air....
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler |
Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers |
      10-11-2012, 07:04 AM   #18
vapore0n
40
Drives: 2010 335i
Im guessing they are refering to using a jack on the center point of the car. Which is completely fine as long as the glove doesnt slip. Some people use a piece of wood.
After its up then you can put towers on the side jack points
I destroyed one of the plastic jack points using a standard jack to lift the car up. Learned the hard way.
      10-11-2012, 07:38 AM   #19
SpmnE9zero
SpmnE9zero's Avatar
505
Drives: JB 33ZERO
2006 330xi  [0.00]
Your missing my point...
I dont care where you jack a car up from, using a baseball glove and or piece of carpet to aid in jacking a car up isnt what I would consider the best way to accomplish getting jack stands under a car.
I see no reason to use anything to jack a car up at the jack point location. You arent going to damage anything there as long as your careful. The only area of concern for damage would be the plastic jacking points, hence the Jack Pad Adapters. If cars were meant to be lifted with baseball gloves, they would come equipt with a Rawlings (maybe even autographed by Jose Canseco... if your lucky) next to the invisible spare tire in your trunk.
You guys can all do as you please, not going to affect me one way or the other, but the last guy who had a few thousand lb car land on him... thought his plan of attack was bullet proof too!
      10-11-2012, 07:47 AM   #20
335BBS
55
Drives: 2009 335 coupe.
Gotta love all the "FACTS" in this forum.
      10-11-2012, 09:12 AM   #21
gpb
Drives: 335i Cabrio
Yeah, and if people were meant to walk around upsidedown and naked they'd be born that way. Oh wait, we were!
Seriously though, I assume you're smart enough to use jack stands instead of relying on a jack to keep the car in the air by itself. Since you can't exactly swap them while the car's in the air, one is either jacking using the jack point and using the jack stand on a different spot or vice versa. Do you use any sort of protective layer for the off-jackpoint contact or no?
      10-13-2012, 06:13 AM   #22
Efthreeoh
General
17314
So you obviously don't know how to properly lift the E9X chassis. The DIY section and the Maintenance section both cover this in detail. The chassis has two central jack points, one for the front and one for the rear, where you lift the car with the jack and then place jackstands under the plastic lifting points on the rocker panels. The front lifting point is under the engine and is visible by the round indentation in the plastic undershield. The rear jacking point is the rear differential iron case (not the aluminum cover).
