iPhone Recording with External Microphone (No Wind Noise)
10-07-2012, 04:38 PM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Most recently I've switched over to just using my iPhone for all recordings. Although it lacks a wide angle lens, the HD quality is pretty good and most importantly it allows me to run my lap timer software simultaneously hence I don't have to go through the hassle of overlaying an external video. But I still wanted to be able to run an external microphone with the phone to avoid the wind noise I get from my first generation GoPro.
I did a quick search and found you can purchase a standard 1/8" 3.5mm non-powered microphone and some adapter to run an external mic. Here's a test using iPhones standard video internal mic vs external mic with adapter: Internal (you hear music playing) External (no music only exhaust!) The only question now remains if my Lap Timer software can recognize the external microphone. I've raised the question to the software developer as it currently does not but hopefully it should be a quick fix seeing how the iPhone is clearly capable of doing so. Last edited by 3002 tii; 10-07-2012 at 05:01 PM.. |
10-16-2012, 04:18 PM | #2 |
Freight Dawg
104
Rep 2,103
Nice work! Might try this out with my Contour.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
