Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 335i Check engine light ON/OFF @ 6000+ RPM?
      10-07-2012, 02:10 PM   #1
jonho90
jonho90's Avatar
Drives: 2007 e92 335i
I recently installed the JB4 tune on my 335i.
My engine light came on when I was going at about 6000rpm+ and it automatically turned off within the next 5-8seconds? This happened twice and I'm not sure what's going on.
I also installed an oil catch can, and to prevent the tube getting squeezed to hard when I put the engine body shell back on top of the N54 engine, I did not tighten upper nuts (closer to the windshield). I did tighten the two nuts down below though. Could this be the problem?
I recently replaced my spark plugs about 2000km ago, so I doubt it could be a misfire? but when I was going at 6000rpm+ @ 130km/h, it did vibrate quite a bit.
      10-07-2012, 03:33 PM   #2
straightcashhomie
straightcashhomie's Avatar
75
Drives: 335i
Sounds like it could be a dme failure ..
      10-07-2012, 05:01 PM   #3
jonho90
jonho90's Avatar
how would i verify that this is the case and how do i rectify the problem? replacing the DME is gonna be costly right
      10-07-2012, 10:29 PM   #4
straightcashhomie
75
Drives: 335i
plug in the usb and read codes, it could be anything spark plugs injectors ignition coils. it all depends, the codes will help distinguish the problem
      10-08-2012, 02:55 AM   #5
jonho90
jonho90's Avatar
my boost guage is not moving either, could it be the turbos...some kinda failure?
      10-08-2012, 04:56 AM   #6
jonho90
jonho90's Avatar
OK, I literally had to connect my laptop and speed so that the engine light came back on and I could quicky click read code.
It shows this:
30FF Boost under target - poossible boost leak
What should i do next? Take it to mechanic? I recently installed the JB4, Injen DCI, Stett CP + Tial BOV, BSH OCC
      10-08-2012, 10:49 AM   #7
straightcashhomie
75
Drives: 335i
It shows this:
I would check all of my installs to make sure everything is in tightly, if you still cannot find the issue I would bring it to an Indy shop. Boost leak could just be a user install of something, good thing we didn't see DME or misfires lol.
      10-08-2012, 01:56 PM   #8
amill411
amill411's Avatar
15
Drives: 2008 335i E92
Sounds like you may have installed JB4 wrong.
Did you double check everything?
JB4 and other stuff
      10-08-2012, 02:11 PM   #9
jonho90
jonho90's Avatar
i think it's probably either the charge pipe or DCI.
the JB4 controls works fine on my dash control so I doubt so? I don't get what you mean by installing it wrong. I wouldn't be able to read the codes if I did haha
07' 335i e92
JB4, Injen DCI, Stett CP & Tial BOV, BSH OCC, BLACK VMRs 19", Interior LED Kit, AC Schnitzer Race Pedals
Next Mods (PM ME if you have any): Oil Cooler (Retrofit), AR DPs, BMS Trunk-mount Meth Kit, whichever FMIC
      11-25-2012, 10:32 PM   #10
alexman360z
13
Drives: bmw 335i
did you ever figure out what happened to your car?
