Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > PETROL Wheels Bohemia offset q's please help
      07-31-2007, 12:30 PM   #1
Guga79
Guga79's Avatar
Drives: 2006 330i AW
Will these offset work on a E90 330i sport package
19x80 5/120 ET35 Front
19x95 5/120 ET45 Back
What size tire should I use?
2006 E90 330i Alpine White - Gray Leather - Aluminum Trim - ZSP - ZPP - ZCW - Xenon - Tint - Logic7
      07-31-2007, 01:55 PM   #2
montreal_bimmer
OEMconcept
montreal_bimmer's Avatar
Italy
174
Drives: BMW
2006 325i  [10.00]
put a 10mm spacer on the rear and you will be fine....
      07-31-2007, 02:06 PM   #3
6MTFTMFW
6MTFTMFW's Avatar
84
Drives: 2018 F30 340i 6MT
2019 BMW 440i  [0.00]
2018 BMW 340i  [0.00]
You don't want to run any spacers on e90 less than 12mm, 15mm is better, search and you'll find a lot of info on those things cracking in less than 12mm
      07-31-2007, 02:39 PM   #4
montreal_bimmer
OEMconcept
Italy
174
Drives: BMW
2006 325i  [10.00]
so then go 12mm spacers, 45mm offset is too high for 19x9.5 rears....
33mm rear offset should be good....
      07-31-2007, 03:25 PM   #5
Guga79
Guga79's Avatar
I guess I'll look for another wheel. I really dont want to put spacers
      07-31-2007, 03:29 PM   #6
JOSG328I
JOSG328I's Avatar
18
Drives: 2007 328I Sedan
2007 328I  [0.00]
I think the wheels you are looking for only come 19x8.5 with a 32mm and 19x10 with a 30mm, if I am not mistaking I'm not positive though.
      08-01-2007, 12:24 AM   #7
pika
Drives: e909
no spacer rules
      08-01-2007, 12:44 AM   #8
evoi19
evoi19's Avatar
No_Country
1524
Drives: 2022 G80C
if you can, find the right set of wheels with the right offset.
et30 in the rear is perfect for the sedan. I'm running 19x9.5 et30 on 275/30 and it runs perfect. No rubbing since i've put them on and it's pretty flush with the fender.
