Steering Wheel replacement help
09-30-2012, 09:30 PM | #1 |
Rep 236
I'm trying to take off my old steering wheel and I tried to follow the DIY, but I can not find the spot to push out hte airbag with the screw driver.
And I was looking at the steering wheel and mine but it seems like there's no way to get to the air bag clip. Mine is the one with paddle shifters. Is there a difference from what I've been reading and youtubing? |
09-30-2012, 10:20 PM | #2 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
You need to find the little slits on the sides of the steering wheel. If you push the screwdriver into them just right you'll feel it hit a spring clip and that side will pop out.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
10-01-2012, 02:24 AM | #3 |
Rep 236
yeah I found the slit that goes around the wheel, but even a long bladed knife I could not find it.
Even looking at the replacement steering wheel, I don't see how the metal base would even give me access to the clips. |
10-01-2012, 08:52 AM | #4 |
89
Rep 3,732
Drives: BMW S1000XR
It is not a slit...there are two holes that are covered with material the same color as the wheel. You can see where they are located due to the dimple in the skin covering the hole. Once you find it you'll see how easy it is to release the air bag. GL
see... http://www.e90post.com/forums/showthread.php?t=19680
BMWCCA member |
10-01-2012, 12:17 PM | #5 | |
Rep 236
