Winter rim/tire setup
09-30-2012, 07:33 PM | #1 |
Rep 113
Greetings
I have read people buy incorrect rim/tire for there winter tire setup and am worried about falling into the same issue. I just got the car (2007 bmw 328i coupe (i am assuming with sport package), I am looking for winter tire/rim combo for this car (Car is canadian from quebec) dont know if that makes a difference. The current tire on the car (front 225/40r18, rear 255/35/r18). Do the winter tires need to be rft? Do i need a TPMS for the winter setup? I read blizzacks rfts are a a good setup. Would 17" rims fit on this car? Sorry, just a noob looking for proper winter/tires setup. I do a lot of driving so the best winter tires would be preferred. Thank you |
10-01-2012, 10:36 AM | #2 |
Moderator
369
Rep 4,745
Many Eliminate the stagger and use 225/40R18 front and rear. This works very well for winter and results in better winter traction. You can use either run flat or non runflat tires for winter use.
For TPMS, Are your original equipment valve stems rubber or metal? When this vehicle is equipped with OE rubber stems, it uses a system that does not use pressure sensors. Instead, we it uses a system that detects how many times the tires rotate/spin in a given distance (a tire low in pressure is deflected and rotates more often per mile). If one tire spins more often than the other three, a warning is sounded. This type of system does not use TPMS sensors. If they are metal, it usesTPMS sensors. We do have 17" wheels that will fit the car for winter using a 225/45R17 tire size on all four corners. There are handful of wheels we carry that will clear the brakes and work well. Two of the more popular choices have been the Sport Edition A7 and Rial Salerno. Winter http://www.tirerack.com/a.jsp?a=AH8&...nter/index.jsp More information is available in the winter sticky post at the top of this forum.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
10-01-2012, 04:39 PM | #3 |
Rep 113
Thank you Gary,
Very informative! Just another question, in your opinion what would be the best RFT and non-RFT you have for winter? Not looking for performance, just want to make sure car is not sliding etc. in the snow/ice. Thanks again, |
10-02-2012, 09:32 AM | #4 |
Moderator
369
Rep 4,745
Top non run flat tires for snow and ice traction are the Bridgestone Blizzak WS70 and Michelin Xice XI2/Xi3. The best run flat winter tire for maximum snow and ice traction in 225/40R18 is the Bridgestone Blizzak LM60.
10-08-2012, 03:57 AM | #5 |
Rep 113
Hi Gary,
I ordered the following, In the order I added what you had In the winter post for the forum discount and also for you to look at the order if all is well with product I picked. Will my invoice show this discount? Thank you Item Description Availability Qty. Price Each Item Total 18x8 Rial Salerno Anthracite Painted for 2007 BMW 328i Coupe Sport Package In Stock 4 225/40R18 Bridgestone Blizzak LM-60 RFT Run Flat, OE Vehicle Use Only for 2007 BMW 328i Coupe Sport Package In Stock 4 These tires and wheels will be mounted and balanced at NO ADDITIONAL CHARGE. |
10-08-2012, 11:21 AM | #6 |
Moderator
369
Rep 4,745
Unfortunately the Tire Rack does not offer discounts (even to forum members). However when ordering through http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp and referencing "Gary/E90Post" as your 'previous contact' a portion of the proceeds goes to support the E90Post site.
06-02-2013, 11:09 PM | #8 |
Rep 113
Hi Gary,
Just a question regarding the winters i purchased last year. What should be the proper tire pressure for these winter tires again? Thank you 18x8 Rial Salerno Anthracite Painted for 2007 BMW 328i Coupe Sport Package In Stock 4 225/40R18 Bridgestone Blizzak LM-60 RFT Run Flat, OE Vehicle Use Only for 2007 BMW 328i Coupe Sport Package In Stock 4 |
06-03-2013, 12:33 AM | #9 |
287
Rep 1,710
So a square setup is better for winter? Any other advantages?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
06-03-2013, 04:10 PM | #10 | |
Moderator
369
Rep 4,745
06-03-2013, 04:11 PM | #11 |
Moderator
369
Rep 4,745
The more narrow tires typically perform well in unpacked snow and slush. The ability to rotate the tires to maximize tread life is another advantage.
